Threads: 49
So I have purchased the de-coke kit. Second hand but it's a good start. It won't be fitted straight away due to other MOT jobs but fingers crossed it won't be long.
Main reason I'm fitting it is because I use a blended fuel mix of petrol/diesel and WVO. This can cause something called ring gumming which is bad for the engine as it eventually contaminates the engine oil with fuel (amongst other problems)
Anyway less of the negatives. I'm planning on buying an endoscope to have a mooch before and after also I'll be looking at what mapping options I have. It will be interesting to see how it compares to an intercooled engine.
Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Interesting stuff. How do you plan on getting it all timed in to run when required rather than all the time etc?
How come you run a mix of all those types of fuels? Must be a nightmare to fill up having to mess around with all that?
Threads: 49
It works off a pressure switch so when you reach your desired boost it blasts a very fine mist into the inlet manifold.
My fuel mix is pre mixed and filtered before I stick it in the tank so it's easy enough.
Threads: 66
Car Model/Spec: 306 Estate - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
Would this be similar to the aem and devilsown kits available off the shelf? Looked at them a few times because of the claims of reduced intake and exhaust temps but never made the leap or pushed looking into it
Sent from my BLA-L09 using Tapatalk
Still Living For The 306
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Infact, rethinking, if you fancy doing it properly, you could have a variable pulse width output also by using the turbo control valve output, if you used a reasonable sized FET on the output to drive the pump. If you're not thinking of using the turbocharger control, just force the governor switchon/switchoff hysteresis maps sky high so the governor never switches on and you're left with the base precontrol maps which are based on RPM and injection quantity (even selectable between demanded IQ from the pedal position, or actual limited quantity).
