double relay
double relay
Pug 306 2 l hdi diesel ph 3, 2000/2001 estate.
The double relay, would that be a BITRON 240 109 please.
Also is the cooling system "heaters" relay socket board, the board that the 2 relays ( and fuses from memory ) plug into available as a new part, as one of the relay sockets has melted somewhat, or is it a breakers for that ?
probably cheaper to get it from a breakers as I presume itll be a difficult part to source!
oh brill, there is a wiring diagram on its lid so probably possible to make one from 2 relays and some wiring.....also for the coolant heater relays also.
The heater plugs in the coolant heater are the same as the engine start heater plugs??
The coolant heater plugs are not the same as the HDi cylinder glow plugs. The original coolant heater plugs are not available to buy. 1.9 XUD glowplugs are a similar size so that's what people use to replace them.
Thanks for that heads up tom.
(21-12-2018, 12:44 PM)Toms306 Wrote: The coolant heater plugs are not the same as the HDi cylinder glow plugs.  The original coolant heater plugs are not available to buy.  1.9 XUD glowplugs are a similar size so that's what people use to replace them.
they are a very worthwhile "repair" to do. Smile
Hate Housework!
  Ecu/Double relay problem Mangarn 9 10,750 29-04-2021, 08:47 PM
Last Post: Mighty306
