Egt Limit for Gtb2062vklr?
Hi Friends.
What can a gtb2062vklr allow concerning the maximum egt on a Xud11T? For safe uses.
Thanks
Diesel parts designer:
-HDi/1.9td and 2.1 XUD11T forged HBeam conrods available in stock
-Custom ARP Head Studs kit available for HDi/1.9Td and 2.1 XUD11T
-Aluminium damper pulley for Hdi/Xud11T
-MFS prechamber for XUD
Ask for delivery
I didn't even know they made a gtb2062vklr to be honest.
Ask garret be your best bet
Hi Piggy
In fact, it's a GTB2060VKLR with a MFS 62MM
I changed the angle of the outlet compressor
For the fitting of the KN filter, i made an adaptator
Ask for delivery
Beauty,
As with all VNT's, upto 800 should be fine.
I have seen 1000+ many times with no issues for short bursts, but 800 seems safe for long hauls.
1300 is when stuff can go real wobbly and you want to see the death of your blower.
All subject to opinion based on different peoples experiences
Thanks Dave.
First test with 1.4Bar and 9mm headpump. I reached to 690deg.
I think with the next 11mm it will increase fastly....
But i gonna check frequently....
This turbo is wonderful!!!
Ask for delivery
I used to see about 800 on a sustained pull with 11mm gt2052s blowing clean no smoke. I could get it higher and did a few times. I had to fettle it a fair bit though. First setup of the 11mm I was seeing 900+ a few times before I got round to changing anything. Seems to have lived on fine though.
Ok. Eager to fit my futur 11mm pump
Ask for delivery
  Egt Limit for Gtb2062vklr? Biggen 0 2,270 23-06-2018, 09:56 PM
Last Post: Biggen
  Safe egt limit anto 13 9,791 25-04-2013, 11:05 AM
Last Post: andywhy
  Rev limit David 12 8,129 03-02-2013, 11:23 AM
Last Post: 4WayDiablo
