Timing belt Tensioner Bolt
Hello all is it possible to get a new Bolt which supports the timing belt tensioner and then the tensioner bolt screws into. This goes into the block using an allen key and then the tensioner bolt screws into it?
you would be best aaking a helpful parts man tbf, or getting to a breakers.
136 tooth? I recall buying one when swapping from Peugeot.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Hello there yes I believe 136 Teeth using the manual tensioner.
Kit attached below.
https://www.ebay.co.uk/itm/Gates-Powergr...1438.l2649
Part 0820 17 Qty 01
(MUL) PILLAR SCREW
M8X125(2) LG 16-34
Discussed as being NLA here, so that's why Welshpug says find a helpful parts man.
http://www.306gti6.com/forum/showthread.php?id=163156
I now have a brand new one a dealer in Glasgow had stock.
  Timing Belt with water pump kit mackat 13 7,174 24-04-2016, 06:36 AM
Last Post: mackat
  Timing Belt Kit paulgtt 7 4,151 21-10-2014, 08:22 PM
Last Post: miles
  peugeot 306 2.0 16V timing belt nikola_bb 6 5,620 04-10-2013, 08:26 PM
Last Post: PUGNUT_XS
