Breaking - Black 98 GTi-6
Last few bits off this 6 before i pull the engine and scrap the shell....no reasonable offer refused as they will go with the car if still here.....can post all of this lot too. Most will only cost a couple of pounds to post. Heavier/glass bits perhaps a little more
Front wing trim bits (both) - £5
Passenger side rear light - £5
Seatbelts (both) - sold
Front end loom (not including engine loom) - pending
Fuel door and dummy fuel door - £10
Wiper arms with good Bosch blades - £10
Opening rear quarter windows - £10 each
Washer bottle and pump - pending
TA Technix coilovers - £60
Rear beam - sold
ABS Pump - £10
Wiper motor and linkage - sold
Last few remaining bits from this 6. Be available for a week until the shell gets scrapped. If any of its still here then, it goes with the shell. Car was a 98 R phase 2.
Entire front end loom (minus engine loom) Pending
Steering rack Pending
Std shocks and -40mm springs Pending
TA Technix coilovers Sold
Fuel filler neck £5
Heat shields £5
3 arch liners (2 rear, one front) Pending
Bitron unit Sold
Rear light £5
Good clutch cable £10
Wiper motor Sold
Washer bottle Sold
Twin fan unit Sold
Airbag ECUs £10
Hi Ben,
I will take the std shocks with lowering springs and possibly the arch liners and wiring loom.
Could I collect one evening in the week or at the weekend?
Paul, yes, that's fine. Friday night or the weekend as I'm out Tues, weds and Thurs.
That's fine can you text me your address and we'll sort it out, 07790 457159. Thanks
is the screenwash bottle standard on all models?
if so, can I request it and the bonnet blanket.
please pm total inc. postage.
Hate Housework!
I'll take the wiper motor off you Ben.  I guess it's quite heavy so does £10 including shipping seem fair?
Sorry if you've already posted the fan relay cover as otherwise you could package them together.
Cheers,
James
(11-09-2017, 06:19 PM)Mighty306 Wrote: I'll take the wiper motor off you Ben.  I guess it's quite heavy so does £10 including shipping seem fair?
Cheers,
James
Sent you a message James
(11-09-2017, 04:08 PM)Magenta Sunset Wrote: is the screenwash bottle standard on all models?
I think it is bud. Can't see any reason why it would be different on the 6. Had a twin outlet pump for the rear washer which I assume all 306's had.
Right, last few bits to go...
Fuel filler neck £5
Heat shields £5
Rear light £5
Airbag ECUs £10
Wing mirrors £15 (both)
Still got the wing mirrors and the front end loom if anyone is interested?
  Breaking Black 3dr HDI Dturbo rocker8742 76 54,254 10-02-2017, 08:55 PM
Last Post: rocker8742
  Ph2 3door black D Turbo - breaking for parts Dazecoop 18 11,282 23-12-2015, 11:44 PM
Last Post: Dazecoop
  Breaking 5 door black Hdi. Chris1357 31 13,353 13-03-2015, 10:20 PM
Last Post: jonas306
