Breaking - Black 98 GTi-6
Last few bits off this 6 before i pull the engine and scrap the shell....no reasonable offer refused as they will go with the car if still here.....can post all of this lot too. Most will only cost a couple of pounds to post. Heavier/glass bits perhaps a little more
Front wing trim bits (both) - £5
Passenger side rear light - £5
Seatbelts (both) - sold
Front end loom (not including engine loom) - pending
Fuel door and dummy fuel door - £10
Wiper arms with good Bosch blades - £10
Opening rear quarter windows - £10 each
Washer bottle and pump - pending
TA Technix coilovers - £60
Rear beam - sold
ABS Pump - £10
Wiper motor and linkage - sold
#32
Last few remaining bits from this 6. Be available for a week until the shell gets scrapped. If any of its still here then, it goes with the shell. Car was a 98 R phase 2.
Entire front end loom (minus engine loom) Pending
Steering rack Pending
Std shocks and -40mm springs Pending
TA Technix coilovers Sold
Fuel filler neck £5
Heat shields £5
3 arch liners (2 rear, one front) Pending
Bitron unit Sold
Rear light £5
Good clutch cable £10
Wiper motor Sold
Washer bottle Sold
Twin fan unit Sold
Airbag ECUs £10
#33
Hi Ben,
I will take the std shocks with lowering springs and possibly the arch liners and wiring loom.
Could I collect one evening in the week or at the weekend?
#34
Paul, yes, that's fine. Friday night or the weekend as I'm out Tues, weds and Thurs.
#35
That's fine can you text me your address and we'll sort it out, 07790 457159. Thanks
#36
is the screenwash bottle standard on all models?
if so, can I request it and the bonnet blanket.
please pm total inc. postage.
Hate Housework!
#37
I'll take the wiper motor off you Ben.  I guess it's quite heavy so does £10 including shipping seem fair?
Sorry if you've already posted the fan relay cover as otherwise you could package them together.
Cheers,
James
#38
(11-09-2017, 06:19 PM)Mighty306 Wrote: I'll take the wiper motor off you Ben.  I guess it's quite heavy so does £10 including shipping seem fair?
Cheers,
James
Sent you a message James
#39
(11-09-2017, 04:08 PM)Magenta Sunset Wrote: is the screenwash bottle standard on all models?
I think it is bud. Can't see any reason why it would be different on the 6. Had a twin outlet pump for the rear washer which I assume all 306's had.
#40
Right, last few bits to go...
Fuel filler neck £5
Heat shields £5
Rear light £5
Airbag ECUs £10
Wing mirrors £15 (both)
#41
Still got the wing mirrors and the front end loom if anyone is interested?
  Breaking Black 3dr HDI Dturbo rocker8742 76 57,434 10-02-2017, 08:55 PM
Last Post: rocker8742
  Ph2 3door black D Turbo - breaking for parts Dazecoop 18 12,271 23-12-2015, 11:44 PM
Last Post: Dazecoop
  Breaking 5 door black Hdi. Chris1357 31 14,024 13-03-2015, 10:20 PM
Last Post: jonas306
