Threads: 5
Car Model/Spec: Peugeot 306 1.9 XUD Dturbo S
Replacing my clutch shortly for something decent like a Helix or Sachs. I also want to run a upgraded flywheel and had the gti6 in mind. Will it work? Are there Any other good upgrades as far as the flywheel is concerned ? I'm running a hdi gearbox. Any help will be appreciated
Threads: 127
33
Car Model/Spec: ZX Volcane TD
won't have the correct pickup on the back of the flywheel for rev counter iirc
Threads: 591
54
I thought it would....
Only thing is afaik, there is no locking pin for timing
Threads: 90
54
Dash in the GTI6 is driven from the ECU not the sensor directly, the GTI flywheel will be missing a locking peg hole, and the marks for the tacho. Do you mean you want to upgrade to an aftermarket billet style GTI6 flywheel? As cant see the stock one is much of an upgrade?
I have done various things in the past to make tacho's work from incorrect flywheels, so is possible, but much easier to just keep the system that works....
Threads: 42
28
stock flywheel is 6.5 kg for an xu10, what's an XUD flywheel weigh? a bit more i'd imagine as they have much less taken out between the bolts and less of a dish on the back.
Threads: 591
54
Xu10 flywheel is 2.5kg lighter
Threads: 42
28
05-09-2017, 11:12 AM
(This post was last modified: 05-09-2017, 11:13 AM by welshpug.)
nice cheap roughly 25%+ lop off the rotating mass then, most of that is around the outside too.
Threads: 5
Thanks for the info guys. I just want a lighter flywheel that will add a bit more response and output. Is there any good ones out there that aren't worth a fortune? Nothing over 300.
Threads: 127
33
have an engineering shop skim lighten a stock one for you - shouldn't cost you more than about £20/30
done it twice myself now
Threads: 371
29
Car Model/Spec: ford fiesta
(05-09-2017, 08:02 PM)Eeyore Wrote: (05-09-2017, 06:12 PM)Logue1996 Wrote: (05-09-2017, 04:34 PM)zx_volcane Wrote: have an engineering shop skim lighten a stock one for you - shouldn't cost you more than about £20/30
Thanks for help. It won't need balanced after will it ?
i imagine they will lighten and balance it.
Yeah they balance when lightning them. My local one balances them on a carnk though. I have to supply a crank for them to balance them with normally
