Help sourcing gaskets...
Can anyone help find the part numbers for the following?
[Image: 9b3087aa551698a9ce4cf0bc87775797.jpg]
2- the gasket from thermostat housing to the block.
10/11- 2 small plastic o rings sealing the 2 sensors on? (Not in diagram)They disintegrated on removal, however i was just going to use a general o ring for these if possible.
Help appreciated
10/11 should have copper washers on from memory they come on the sensors. I think i have a couple of spare sensors banging about somewhere can look tonight for you and send them in post if you cover the postage. Dont want anything for them. As for the other gasket you can buy them in the head kit or singully off ebay if you get the part number from service box. Only a few quid for the head kit.
When i removed them there were what i presume were plastic washer that just fell to pieces when they came out, if you have some ill take them, thanks mate.
Thats it, I've always had problems accessing service box otherwise i would have checked the numbers on there.
you may of sorted it by now, if not:
quick ebay of the part number:
XUD Gasket
Thanks for that, yep ive sorted out service box now all good cheers
good to see its sorted now man
(16-08-2017, 10:54 AM)bashbarnard Wrote: good to see its sorted now man
I haven't found those washers yet, i don't know if the seal was part of the sensors/ plugs as they arn't there on the exploded diagram as a separate piece, so presume the sensors sealed themselves.
  where the best place to buy head gaskets daniel909 20 8,782 12-10-2014, 04:52 PM
Last Post: londondan86
  Head gaskets David 5 3,546 18-05-2013, 11:22 PM
Last Post: Dave
  Gaskets for turbo adaptor plates Ben 12 9,044 02-05-2013, 12:50 AM
Last Post: samass
