Coil Springs
Coil Springs
Hello all I have a broken front coil spring on my Ph3 GTi-6
I am planning to change the Pair is the correct O.E part number 5002P9?
Cheers
(03-07-2017, 02:18 PM)crazydave Wrote: Hello all I have a broken front coil spring on my Ph3 GTi-6
Cheers
Yep, I reckon that will be the right part number.  If your air con has been stripped out to lighten the car the 5002.P7 may be a better match.  They're expensive though, as I found out when I enquired recently (nearly £90ea + VAT).  Only option if you want to stay at standard height however.
Thanks for that information.
  coil springs barca19784 1 1,770 20-05-2016, 07:49 AM
Last Post: toseland
