any tips on sealing up this rear mess
so bar the seepage from the hole it seams to be leaking around that bit that slots in the block any tips, i know i need the 2 seals from pug but is there any thing i have missed.
might as well replace the crank seal as well whilst you have it apart, sump has to come off obviously so you can remove the main cap.
How funny, the crank seal I put in mine a few ago just started pissing out, took he box of today and was greeted with something very similar.
I've done loads of crank seals and never had a problem. Any amazing tips?
dont whack it in too far!
GTI6 Info
yeah, and use decent seals, like Payen, also if you use a good seal like a payen seal they have a tool for fitting to ensure the lip is not damaged.
Agree with what welshpug has said here, i got a payen one which comes with the cup to help fit it. Makes it so much easier to fit and you can be more confident about not damaging the seal when fitting it as well.
Im gonna ask a really blonde question but should oil not come out the bolt holes when the flywheel bolts are out??
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Oil comes out because the holes go right through.
When replacing the line seal make sure they don't stretch, I used some tin between the cap and block when sliding the cap in to position. You might be able to cut up a coke can and use that.
[Image: DSCN8526_zpsp5s10sg7.jpg]
Make sure there is no more then a 2-3mm sticking out any more the seal has stretched too much.
[Image: DSCN8528_zpsj9ss5azb.jpg]
Photo's were taken when I did the '6. Going to be doing this on my Dturbo soon, I've got the line seals just waiting on the large oil seal.
Where do you guys get the Payen oil seals from?
why would oil not come out of the sump if a hole is not blocked by a bolt?
Just making sure. Half awake blonde moment [FACE WITH TEARS OF JOY] had to do my seal on the last clutch
Justin_306DTurbo
the hockey stick seals should be trimmed down to 1mm after leaving them a shirt while to shrink back, they come longer than required.
  Help clean this mess up C.A.R. 22 11,425 21-08-2013, 11:06 PM
Last Post: titch
