drivers door loom wires
Before I start to fix the drivers door loom lock popping problem this weekend, would anyone have a diagram explaining the door loom wire colours and or codes please ? ph 3 1999/2000 2 litre hdi turbo diesel estate lx.
Do pug do a repair piece to include the car loom side door connector with say 2 foot of wires ?
The door has the lock, mirror controls for each side, the window control for each side, lights for the control buttons and speaker, and an earth I presume ?
This morning as well as the door being "frozen" to the car ( finaly unforze the rear passenger door and got in that way !! ), the dead lock refused to open, the lock only turning anticlockwise !!, but finally got in. The engine started really well as usual, and when the car heated up ( 3 degrees centigade was flashing, fist time I have seen the temp gauge flashing !! ) and the sun finaly woke up, the car behaved, all day!! thank god.
Anyway you know what i will be doing tommorrow, hope it don't rain.
check out the guide section i did one on the loom repair
http://306oc.co.uk/forum/showthread.php?tid=11512
http://306oc.co.uk/forum/showthread.php?...#pid567958
GTI6 Info
brilliant brilliant brilliant, thank you so so much, will print off the info needed and read thread several times, then will "go in", loved the crock clip device, brilliant. didn't spot this " how to" in guides section at all.
Peugeot no longer sell the repair loom, eBay is your best bet.
For heatshrink, there's two types, get the self-adhesive one, so it self-seals and provides a watertight connection. - Get this in different sizes as well.
http://uk.farnell.com/webapp/wcs/stores/...a=true&vw=
Solder - Use the 60/40 Lead - Tin combination, it's much easier to use.
http://uk.farnell.com/multicore-loctite/.../dp/289838
Wire stripper - Use the automatic wire strippers, it's much easier than doing it manually.
http://uk.farnell.com/duratool/ws-150/wi...dp/1257167
I also bought an octopus holder
http://uk.farnell.com/proskit-industries...dp/2134959
^ P.s, the above is to replace the door loom with the repair door loom kit
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,944 29-09-2017, 08:58 PM
Last Post: paulgtt
  driver side door loom callumh121 2 3,179 20-01-2016, 03:40 PM
Last Post: callumh121
Rainbow 306 door loom Owen_G_ 1 2,459 10-09-2015, 11:34 PM
Last Post: cully
