Threads: 213
2
Car Model/Spec: HDI
So ive been using neutral going downhill as the speed stays the same or climbs more compared to always decreasing in gear downhill in the 306, what is the science behind it? Most people say it doesn't use any less fuel. Does it use more, less or the same fuel? I know engine braking uses less fuel than using the brakes.
Threads: 591
54
Closed throttle, in gear, uses almost no fuel. Idling in neutral uses fuel
Threads: 371
29
Car Model/Spec: ford fiesta
depends upon the way the car is fuelled. take for example the xud vs the dw10. the dw10 will see when youre rolling with the throttle on slightly and inject less. the xud cant tell the difference and will inject said amount wherever your throttle is sitting. so dw10 no, xud, yes.
thats my 2p on this. you have to remeber that every car is diffrent
Threads: 29
Given 7 thank(s) in 7 post(s)
Modern engines supply zero fuel after a certain rpm with zero throttle. Remember reading 205 GTI's was around 2000rpm (not modern I know)
But yes, rolling With no gear selected uses more than rolling in gear.
Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
Dude, go to the pub.
Stop thinking about MPG. it's pointless,.
I Don't Have A 306.
Threads: 8
1
Car Model/Spec: 405 SRDT
Given 6 thank(s) in 6 post(s)
Depending on the car and how new it is this may well be the case.
However, neutral, downhill , means no engine breaking and limited transmission losses, depending on the terrain you are travelling over you may well be able to use the inertia of the vehicle to overcome some gradients that would be totally impossible with the engine at closed throttle in gear. Therefore it is possible to save fuel by coasting.
The grey area of legalities on doing it however are another matter....
Threads: 541
124
In ye olden days when everyone's cars had carburettors' it was probably true but not these days.
