Bosch pump
Bosch pump
Hi
I have the chance of getting a Bosch pump from a Citroen ZX with injectors, pipes and everything to convert from Lucas. It has two sockets a black one and a blue one, the black one is for the immobiliser which I think I know how to deal with, the blue one, I dont know and do not want to buy an electronic advance pump which would need an ECU etc I am pretty sure this ZX pump is not electronic but would like some confirmation if possible, thank you.
pop a pic up if you can Smile
(27-10-2016, 06:28 PM)Mattcheese31 Wrote:     pop a pic up if you can Smile
That's a non-turbo pump anyway in case you're thinking of putting it on a turbo xud
(27-10-2016, 09:06 PM)Mark Wrote: That's a non-turbo pump anyway in case you're thinking of putting it on a turbo xud
It will be going on my LDV Pilot with NA. XUD. I'm trying to find out if it is non electronic and compatible
Hi is there anybody that could let me know if this pump is non electronic and compatible for my LDV pilot with XUD engine,as I have to let the seller of the pump know this week end Thank you
it looks damn like a mechanical set up non ecu looks near enough bang on the same as a turbo bosch pump except the obvious differences
As it's from a Citroen ZX then I'd say it won't have had an ECU with electric advance, however it looks to have the armour over the stop solenoid so was off a car with an immobiliser, but I believe people have managed to remove the immobiliser from them before so it is possible to use one like that.
Hi Thank you for replies the pump set up will be on its way to me next week will let you all know how I get on
Freight  companies lost my bosch pump 4 injectors 4 pipes pump wheel and pump bracket the whole kit, Censored  you know when some times you want to give up Dw 8 engine out XUD in lucas pump wont pump get second hand pump same, find a good bosch set up only for this to happen, wish I had done the 400 mile round trip to pick it up now well and truly pissed off Angry
  Slack in bosch pump? dt_ 14 11,217 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,315 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,004 12-03-2019, 06:47 PM
Last Post: Forby
