Threads: 91
83
The answer is actually kinda in my post - from what I see its a confusion over airmass rate over time vs the current cylinder charge mass... One goes up as RPMs increase, the other stays constant for the same boost level (ish... Depends on the engine's Volumetric efficiency)
You don't get more accuracy between the 2.0/2.2 sensor, the accuracy is the same - it just enables the OEM to use a physically larger sensor housing whilst keeping the same resolution and compatibility between ECU software variants.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 24
Also is the maf and airbox we are discussing out of a 307 hdi or a 2.2 c5?
Threads: 117
119
Hold the filters next to each other, iirc the 306 one is slightly wider at the front where the xantia one is a touch longer. The net gain in size is slim to none. If i'm thinking of the right air filter that is.
Threads: 91
83
It's not necessarily proven, I was just opening discussion about the subject... But then a discussion about the size of Xantia air filters started.
