GTI6 catalytic converter gasket?
Should there be a gasket between the manifold and CAT or do the springs pull it tight enough? Just pulled the old cat off and no gasket.
(13-10-2016, 08:18 PM)KevinTW Wrote: Should there be a gasket between the manifold and CAT or do the springs pull it tight enough? Just pulled the old cat off and no gasket.
There would of been a gasket there, normally stays on the manifold, its a mesh fire ring gasket,
I will take the new cat back off and investigate. Thank you.
  Gti6 cam cover gasket? Niall 6 4,225 12-06-2012, 09:48 PM
Last Post: Niall
