Threads: 1
Car Model/Spec: 306 HDi Daily - MK1 Clio 172'd
Hi guys
What bore pipe is recommended for the HDi for a 'stage 2' exhaust?
I'm thinking 2.5"?
I have a 2.5" downpipe, drove 100miles yesterday for what I was told to be a 2.5" straight through cat-back, Turns out it's actually 2" OD (internal is like 47mmish) This seems far too small to me?
Also where might I get a full proper 2.5" system for the 306?
Thanks!
Threads: 1
Car Model/Spec: 306 HDI Meridian
Hi Peter,
look at a specialist exhaust place or Local supplier / ebay google
I have one look at my Profile
Andrew (Saxblower)
Threads: 476
81
Car Model/Spec: 306 Rallye
2.5" is the largest sensible size. you could go 3" but wouldnt be great on a daily and its pretty noisy. 2.5" should see a decent amount of gains over stock
Threads: 213
2
Car Model/Spec: HDI
2.25 is standard, 2.5 is what you want, loads of threads/stickies on this topic....
Threads: 42
28
standard are tapered along the system, not a single straight bore.
how much power are you making?
Threads: 117
119
2.5" will be plenty up to 200bhp on these engines.
Threads: 42
28
enough for 300 bhp tbh, unless its particularly thick walled mild steel.
Threads: 117
119
16-09-2016, 03:50 PM
(This post was last modified: 16-09-2016, 03:52 PM by Poodle.)
Diesels need more airflow than petrols because of the higher afr, plus the heads on these suffer badly with back pressure. You could probably squeeze 250 and be ok, wouldn't want to push it more than that though.
That said, i've yet to see anyone find the exhaust to be a restricting factor at 2.5" simply because no-one tunes them that far lol.
Threads: 91
83
Bullshit.
Go run a diesel at lambda=1 and see what happens.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Yeah diesels move a stupid amount of air. Surprising how restrictive air filters and exhausts can be on a turbo diesel. Moving from 2.5 to 3 inch on mine was pretty evident on Darren's dyno
Threads: 202
58
If you're after a full system, drop us a message and I'll sort a quote for you. I'd agree on going for a 2.5" system, unless you plan to make over 200 bhp.
