27-08-2016, 07:36 AM (This post was last modified: 27-08-2016, 07:56 AM by cully.)
2003!
2025Kg = Gross vehicle mass (GVM)
3460Kg = Gross train mass (GTM)
1110Kg = Maximum permissible front axle mass
1000Kg = Maximum permissible rear axle mass
3460-2025=1435KG
Trailer+load = Maximum of 1435KG?
the Curb weight is listed as 1,364–1,578 kg engine dependant
the GVM is the filly loaded weight so does that mean i can shift more weight to the trailer so i stay below 3460kg
so effectively I could tow 1882KG
I used to drag a mk2 golf track car round with the vectra. Trailer wasn't plated I don't think but was a caravan chassis & stupidly heavy.. Check the suspension unladen, lol.
I'd have thought the Mondeo would be ok. When Dad had his Mk3 ST estate I believe that was 1800kg towing wieght, and the car weighed 1400kg so a 306+trailer isn't massive amounts more, especially if it was stripped.
However, being the estate and the ST version, maybe it had better brakes, something to consider.
mondeo will be fine, my E34 is lighter and also rated at 1800 kg towing weight, ive had a 500kg trailer and a full fat non ac zx 16v behind it perfectly fine.
