Wheel nuts
Wheel nuts
Can someone help me and tell me what wheel nuts I need to fit cyclone alloys ???
Tapered Bolts... Do not use flat seated iirc
(04-08-2016, 07:32 PM)BiG K Wrote: Tapered Bolts... Do not use flat seated iirc
wrong, well mostly
flat seated to fit clones. the later ones had flat seated taper that you can just use the flat seated type on as well. hope it helps
clones use flat seated bolts!
there are two types of clones
early/late
early clones take parallel threaded flat seated bolts
later clones take stepped parallel flat seated bolts
later bolts will NOT fit early clones
early bolts fit both types of clones
more info here
http://306oc.co.uk/forum/showthread.php?...#pid329124
GTI6 Info
(04-08-2016, 07:52 PM)cully Wrote: clones use flat seated bolts!
early/late
more info here
Where's the best place to buy them ??
forums, facebook, peugeot
GTI6 Info
hmmm i'm a little worried now... as i've fitted my clones straight on, but didn't have any idea about the nuts issue?
i'm assuming mine are ok being they have gone straight on and bolted up?
Swallow bolts are also flat seated, you should be fine Pocketfighter.
Rob, which wheels do you currently have? A 1.9 HDi doesn't exist so I can't work it out from your car spec lol. The alloys all come with flat seats, steels come with tapered.
As for where to buy them - not Peugeot unless you're feeling rich, the chromed bolts cost £6 each!! Confused
Thanks given by: PocketFighter
You learn something new every day I guess.... why must Peugeot make everything so complicated!? lol
(05-08-2016, 08:54 AM)Toms306 Wrote: Swallow bolts are also flat seated, you should be fine Pocketfighter.
Sorry 2.0 liter and got steels on. I rang Peugeot and it came to £64 !!!
Bargain, they must've dropped in price since I had to buy some...albeit 7 years ago now! lol
Ebay or facebook you can probably get a set posted for £20 give or take. Smile
  Removing locking wheel nuts? Colactix 12 10,144 13-03-2021, 01:30 PM
Last Post: Colactix
  Wheel Nuts? JTaylor2005 20 11,051 14-05-2015, 06:58 PM
Last Post: Toms306
  wheel nuts thebluepearl 0 1,972 10-10-2014, 07:55 PM
Last Post: thebluepearl
