Threads: 374
38
Car Model/Spec: GTI 6
As titled; easiest way to remove these pins.
Moles grips are struggling to get any movement on it.
Threads: 386
87
Well mole grips is the easiest way... Or a chisel from behind if possible.
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Mole grips or a decent pair side cutters to hold it and lever it out. Its all luck of the draw whether they come out easy or are a complete pain.
Threads: 591
54
In 50% of cases...
I find it easier to bend the arm...then you can get the box off...
The arm/fork will then slide up enough to knock it out with a punch
