Threads: 66
Car Model/Spec: 306 hdi Dturbo
Came across a 206 gti 180 wheel in the scrap yard picked it up and paid 3 quid for it (no airbag) seems like there is a lot involved in getting this to fit a 306? As its not deep enough has anyone fitted one and can point me in the right direction please
Threads: 87
48
think you have to cut or remove the column shroud mate . . .
Threads: 66
The stalks seem to be in the way without column covers unless there is some way to space out the steering wheel a few mil
Threads: 2
Car Model/Spec: Ph3 Cab/ Ph2 GTI6
They do fit
but they sit closer to the stalks (you can push the stalk holder down a little bit.
and as above, the shroud needs cutting back quite a bit.
Threads: 66
Looks like i have a little challenge then, as with airbag there was none do i need a gti airbag or will a standard 206 airbag fit gti wheel? Presuming its the same size?? Popping in to see a metal fabricator this week to see what we can come up with
Threads: 2
same airbag as far as I know.
Threads: 591
54
Yeah the mk2 wheel is a pig.
I found the splines were not quite right, the shroud needs cutting and stalks moving.
Then once you've done that you'll find the seating position even worse as you'll meed your knees at your ears to reach the wheel...unless you have short legs and long arms
Threads: 2
Oh and you really have to commit to fitting it as you need cut of the lugs for the original shroud
Threads: 42
28
loosen the clamp bolt to the lower column and tug upwards, you'll get a bit more clearance then.
Threads: 66
13-07-2016, 09:25 AM
(This post was last modified: 13-07-2016, 09:28 AM by thebluepearl.)
My friend the matal fabricator has said he would weld a spacer onto the wheel, and then proceded to inform me that it would come with many risks, mainly the possibilty of colapsing during an accident........
I have the centre of an old wheel with splines that i could weld onto gti wheel but struggling to get it cut down to correct spacing
Also would need a longer wheel bolt does anyone know of a peugeot that has a longer centre wheel bolt?
Threads: 42
28
f*ck welding a steering wheel
Threads: 371
29
Car Model/Spec: ford fiesta
Yeah please dont go cutting/grinding/weldin a steerin wheel for yours and other road users safteys sake
Threads: 66
The wheel is fitted and you will be glad to know i went against the welding idea now time to get jiggy with the dremel and start trimming the cowel until it fits
Threads: 66
Will take plenty of pics incase anyone fancies this challenge
Threads: 2
I just used the 306 clock spring. The 2nd set of wires are for horn.
All you got to do now is figure out is how to secure the cowl.
Auto cancel on the indicators won't work properly either.
Threads: 20
1
Car Model/Spec: GTi6
I think I saw that wheel lol, I was after the comm unit behind it but someone already took the wheel etc off and had nabbed the comm2000... the airbag was there when I saw it but they are changeable as I fitted a 206gti wheel to my daily 206 and both airbags fit... just make sure you get the later type as theres a screw on type and one held on with the spring clip, you need the latter.
Ohh if you come across any alcantera seats locally can you drop me a bell? after a drivers base (passenger base will do and I'll have it altered)
