Engine loom fire
Engine loom fire
Hi
Just fitted a new starter, once the battery was reconnected the engine loom over heated and caught fire
lucky I was able to disconnect the battery quickly. Check around no cables trapped or nicked. Any ideas? will it happen again if I fit another loom?.
Starter shorting out most likely, I would remove it and replace
It is a brand new starter
stupid question;
was the main lead bolted to an earth or touching some thing around the terminal ? leads would only go on fire if there was a short....yet to see a new starter motor that's fked out of the box ??
I would look carefully that you put wiring on without the main lead touching anything except the terminal it attaches to.
I have seen somebody manage to put both leads with ring terminals onto the one terminal----that also burst into flames and also burnt out the starter as well....
easily test the starter for continuity and rule it out
  ph1 and ph2 engine loom connector differences jirupa 23 22,025 08-02-2021, 12:40 PM
Last Post: Mighty306
  GTi6 Engine loom help MCH 9 9,136 03-06-2016, 03:47 PM
Last Post: MCH
  Hdi engine loom pinouts aggyj17 9 4,677 16-01-2016, 04:03 PM
Last Post: bashbarnard
