No power
No power
Ph2 (98) d turbo.. No boost whatsoever. I have already changed all filters, blanked egr, checked for leaks - none found and no improvement.
Is there anything else I should be checking? Hoping there's an easy fix.. Worse than driving an NAD!
Has the plastic inlet tubing collapsed? (check the inlet piping behind the inlet manifold)
Have you removed boost hose from left side of intercooler and revved engine up to see if there is actually any boost at all?
[Image: sigi-2.png]
Wastegate arm dropped off or something?
Where abouts you to in devon?
Thanks guys, my dad is looking at it for me. He thinks it's a fuelling issue ?
Frosty - I'm just outside Barnstaple Smile
