Highs and lows
Highs and lows
Bug
Whats the recommended personal preference on the suspension on your 306? I used to have 60mm front and i would say matched rear (i didnt do it) but have changed fronts to bilstein b4 struts and 30mm springs but havent had chance to get the rear done as of yet so looks like the bum is on the deck, as i do not know how low it went on rear, would raising it 30mm be fine would someone know how to correct its height without knowing its current lowering or am i better off having it put back to standard height and starting again?
Was going with the theory of from standard lowering front -30 rear would need to be -30 too?
30mm drop is good, though B4s aren't any better than standard afaik. Rear should be set roughly the same as the front, slightly higher if anything.
I have VTS shocks on front which is about 30mm lower, rear is stock and will be sorted asap, but atm I have a socket set, a tool box and an XSi gearbox in the boot which makes her look level ha ha ha
I'm not intending on keeping it like that btw as the box at some point soon will be put in Smile
But yeah 30mm I have found to be just about drivable with all the bloody speed bumps and such, any lower and my front valance will be getting scrapped all the bloody time
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
Is the xsi box any different to the 2.0 cabby box?
i dont believe so, they look identical, both ran the same engine. just it came out of an XSi an not a cabby Tongue
Smile
Not always Grumpy!!
for the rear you measure from the middle or top of the hub to the top of the arch. extend by that 30mm and you should be in business.
Thank you all
So can someone please explain to me what is involved in lowering 30mm all round- parts list work list etc?? Cheers
  Less Lows = Lift? John1.4 25 11,248 18-12-2013, 07:56 PM
Last Post: John1.4
