Gearbox failure
Gearbox failure
#31
Interesting, probably is worth sandwiching a plate between the end of the casing and the cover.
Looks like it'd be much more of a bastard to put something on the other end, but every little helps eh.
Used to run external straps on the old VW transaxles to stop them splaying apart under shock. The pegs behind the shafts and diff.
Everyone has there ways, I know AB motorsport used a larger bearing on the input shaft end which some BTCC box's did but as WP said the gap then between the 2 bearings in the end case got so close it cracked, well on the BTCC ones, you even need to watch when fitting a single plate Race clutch the clutch arm top bearing area can fail as well due to the extra load on it.
Old race box's I did used Roller bearings instead of the bush's which these days for some reason seems all to be forgotten about
If you are smashing gear boxes all the time I'd suggest you start looking at your driving style even with higher than normal outputs.
ML gear boxes are a huge amount stronger and a avenue worth Investigsting at some point for sure. I've never heard of a V6 killing one, I curtainly gave mine some stick and plenty of hard launches. I even drove it 80 miles with no clutch, bumping it on the starer every junction!
Down side to that is gear cables do not give a nice change compared to a well sorted rod set up in my opinion.
