Project 6 cylinder
Project 6 cylinder
The problem is that the engine isn't in the car anymore so it makes things more difficult
Little bit more striping on the engine. Needs a dam good clean
[Image: 484cb417deba827f30f58b07955d7898.jpg]
[Image: acb6280b487fc427e02ac376415f318d.jpg]
Got the black e30 stripped.
[Image: 42035d8bcbf4967fd10273d4944c5d6a.jpg]
[Image: 12bbfd9731951a408a9d638792bae800.jpg]
Use a hosepipe. It's crystalline antifreeze deposits, which were at one time suspended in water...
Most of the accessible stuff will come out with a scrape. Dishwasher tablets when it returns to service will see it bubbling fresh.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(24-03-2016, 01:18 PM)C2K Wrote: Use a hosepipe. It's crystalline antifreeze deposits, which were at one time suspended in water...
Cheers buddy that's what I ended up doing. Got the head off the engine been sent away for a light skim if needed and a pressure test.
[Image: f113b2348a9a8dc41f698d71ee18bcc7.jpg]
[Image: d54bde1e2942b5f457f8c6feae0ab1b5.jpg]
[Image: d680f33fe972ea15ae7ba82afbf70af6.jpg]
[Image: b2360e3a5c58504dbe16b32a0488670b.jpg]
Only issue I have is now getting the crank bolt out to get to the crank seals.
So got the engine apart and started to clean it up and gave it a lick of paint and is starting to look nice if I do say so myself.
[Image: a2713ad5036c52c3d0e3f07793f9eeab.jpg]
[Image: e7ebd007fcd0417c3f9c256447318ef2.jpg]
[Image: fedc4dbd33ebc687c01660746beb6390.jpg]
Also stripped the black bmw basically bare and sent that away to be squashed [FACE WITH STUCK-OUT TONGUE AND TIGHTLY-CLOSED EYES][FACE WITH STUCK-OUT TONGUE AND TIGHTLY-CLOSED EYES].
[Image: 8800490ddb9f25388d3495ba3bd74a9c.jpg]
[Image: 7ead9c3028e95cc6c38c788c06811936.jpg]
[Image: 18ffd0771d40c05b0d19bab760bf998f.jpg]
Hopefully will be getting the engine together next week and soon in the car and get the thing started 😀😀
Sent from my E6653 using Tapatalk
I made a start on cleaning up the head ready for rebuild.
Before
[Image: da268ed5b0d12601402cd3aedb152018.jpg]
[Image: 5bd7186329b653d5db3e56cab31fa776.jpg]
After a splash of gunk and a pressure wash
[Image: e95444a1be0ffacaf2fb21da362f2807.jpg]
[Image: 05694fdd51571b394c4265727c6d4ca9.jpg]
Did you even attempt to sell the E30 shell? Might of got couple hundred for it?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
It was stripped bare therw wernt alot on it. I did offer it to a few local people but they wernt interested. I needed it out the way asap aswell
(27-04-2016, 11:51 AM)aggyj17 Wrote: It was stripped bare therw wernt alot on it. I did offer it to a few local people but they wernt interested.  I needed it out the way asap aswell
Fair enough mate. Smile
S14 Zenki Build
Soo started relaping the valves in the head, installed them and got the rockers in aswell. 😀
[Image: 3803c77630bbf982628bb4de5d97d247.jpg]
[Image: e5a3e4b5dd26ef408b0e6318eec724d5.jpg]
[Image: 223d0ebb7aaaed24efd42ec05f208838.jpg]
[Image: 232641e03e157471e176245a9ed42e79.jpg]
[Image: 15f5b38ad6e580d68611ef33805ef6b6.jpg]
Just need to set the valve clearances and then it should be ready to put onto the block 😀😀. Hopefully I'll get this thing running soon.
Been building the engine up recently got a the head on the block and have got the cambelt on and turning over nicely
[Image: 8616f0a08f1f1e5fb7d6494723ea0757.jpg]
[Image: 3c51f38c05e30e1b2f56912561e0044c.jpg]
[Image: 1f933f6936920079270d386de1ec1a5c.jpg]
[Image: 2fc32e57d54de6d9b37f1a798e5b7aca.jpg]
[Image: ce6dc011371502f42b34acccbd53249a.jpg]
[Image: 24c4142b4d06e24e79e12966d3bbdc67.jpg]
[Image: e16560cfe1ef7fc3e919f094fc0b58a7.jpg]
Been doing a few bits and pieces to the car aswell have got all the wiring and cooling bits off that and getting that ready to pull the engine out. Found out why the engine is siezed the aux belt snapped for the waterpump as I found it wrapped around the viscous fan so it looks like it was heat siezed.
Soooo got the engine built up and it's in
[Image: 3fcff7da3c7b3749ca6ac9d563c48bec.jpg]
Gave the bay a clean beforehand
[Image: 9a51b086e3db35b0ea001c260304f6ba.jpg]
[Image: a5fef19b99ad9ea2b941413e53e479e2.jpg]
[Image: d69b0c3ed838d5ea5de8b4d01b3b149a.jpg]
And the rocker cover to go on that the Mrs has been painting
[Image: 10955182e5da2ca244dd4dc5863651db.jpg]
Going to connect the electrics and check the fuel tank for rust and if it's all good some fresh fuel and see of it will fire
