so..... oil leak and turbo failure.......
my car is dlin the same as the black pug above this
#32
sexystu1987 Wrote:my car is dlin the same as the black pug above this
[Image: 5284ead1-a854-8248.jpg]
On the 306 waiting list.
#33
Haha I think he means his car is doing what mine does in my sig
#34
Is your car slow as shit? Since the black smoke
#35
no its really fast stil
#36
So you don't quite have a boost leak but your over fuelling. I take it you floor it then it smokes?
#37
yea if i go ova the 2000 revs it smokes like any think wat did udo to ur car to make it smoke like that? i just wanna know wat it i because its a lush car! how do i put a pict up of my car
#38
You can upload it as an attachment to the forum or upload to photo bucket and copy img code
As for that smoke.
No smoke no poke
That's how diesels generally work. The fuelling is matched to the pressure of the turbo when its on flow but anything up to that The turbo isn't matching the fuel. You have morea fuel so some comes out as smoke unburnt fuel
#39
yea but i dnt like it so how do i tune it dow a bit
#40
sexystu1987 Wrote:yea but i dnt like it so how do i tune it dow a bit
turn the fuel down or pump the boost up...
It's unburnt fuel as 4way said, so either burn it up or get rid of it Smile
Turn the fuel down or the turbo up. Or best is both
You will have to go back to standard to get no smoke. And will be much slower
#42
do u no were on the car u an turn it down mTe sorry to ask lol
#43
Yeah I do but your best of understanding it before you play with it. Have a look at guides
#44
ok sweet were wil i find the guides?
#45
In the guides section... lol :-p
#46
<!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=31&t=158" onclick="window.open(this.href);return false;">viewtopic.php?f=31&t=158</a><!-- l -->
have a read through that
Seriously, if its smoking like hell at anything over 2k then it isn't just overfueling, no way in hell! if it was tuned that badly it would smoke more below 2k than once the turbo is spooled up....................................................
Team Orange Engine Bay
#48
so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted
#49
Sounds like your massively overfueling. Some vids would be good and some specs? Pump specs? Turbo type? Tmic?
#50
sexystu1987 Wrote:so wat do u think it cud be den? i really dnt have a clue an just wanna get it fixted
De ja vous? Umm boost leak. Don't ask this question again, I for one won't be replying.
HDi Cabby Project Click
#51
Ummmmm.................maybe it could possibly be A BOOST LEAK
just incase you missed it the last 20 times, this is getting f*cking ridiculous now!
4WayDiablo Wrote:Sounds like your massively overfueling. Some vids would be good and some specs? Pump specs? Turbo type? Tmic?
As per my last post Phill, if it was "massively overfueling then it would smoke more before 2k than after once the turbo is spooled up!
#52
Again, if you still running a top mount intercooler ( a radiator looking thing on top of your engine) check the pipe going into that, if thats fine OR you have a boost gauge and running a steady boost, have a fiddle with the pump
READ THIS FOR PUMP INFORMATION AND DETAILS ON TURNING YOUR FUEL DOWN:
ginge191 Wrote:http://www.306oc.co.uk/forum/viewtopic.php?f=31&t=158
A BOOST LEAK
As per my last post Phill, if it was "massively overfueling then it wous on a ld smoke more before 2k than after once the turbo is spooled up!
Yeah I know I'm just trying to figure this guy out
Maybe he doesn't just mat it from idle or something
I really don't know mark haha
My money is on a boost leak as per my first post but he still says its boosting 2 bar.I'm onlyguessing its on a standard turbo
#54
4WayDiablo Wrote:My money is on a boost leak as per my first post but he still says its boosting 2 bar.I'm onlyguessing its on a standard turbo
this..
Do you have a boost gauge fitted? What PSI/Bar are you hitting when flat out, (3rd/4th gear, uphill if poss)?
#56
I think he needs to put some facts down. We have not got a clue what setup he is running...
#57
londondan86 Wrote:Do you have a boost gauge fitted? What PSI/Bar are you hitting when flat out, (3rd/4th gear, uphill if poss)?
also any noise in the engine bay, out of the ordinary on boost..
4WayDiablo Wrote:I think he needs to put some facts down. We have not got a clue what setup he is running...
Agreed.
From the beginnig. What turbo/pump setup do you have? Is a boost gauge fitted, what is the reading? What mods have been done to it, if you dont know I would contact the seller/previous owner for more info as you really are a bit clueless at the mo.
#59
this..
Can I suggest reading the thread properly then...........the previous owner said it was "tuned to 2bar" also in the first post he said it was fine on the drive home, and now its smoking above 2k, 2 bar is also 30PSI, it isn't, wasn't and won't make that on a lucas IMO! Ruan only managed 29psi on an 11 Bosch so go figure!
Still think its overfueling? or maybe that is popped a boost hose off?
#60
This thread has gone downhill.
I feel we are being trolled
  HG failure? Nathan1305 13 9,084 10-08-2014, 09:53 PM
Last Post: Nathan1305
  Peugeot 306 xrdt oil leak turbo 306__xrdt 5 3,640 18-07-2014, 10:17 PM
Last Post: toseland
  Leak of Pipe Air Leak PaddyPug 5 5,806 18-09-2013, 08:31 AM
Last Post: PaddyPug
