Welding Cages
Welding Cages
Does anyone on here weld cages professionally? I'm looking for a bit of advice with adding a harness bar to my OMP bolt in. What wall thickness tube do I need to use and do I need to use cold drawn tubing? Should I TIG weld it in? I'm looking to get it fitted on Sunday or at least make a good start with the door bars etc..
Rippthrough
P1 XSi track car
2.4 LWB T4
Yeah good call, I should say Phillip knows a bit on the subject.
Minimum MSA spec is 38mm x 2.5mm or 40 x 2.0mm (you can go larger, not smaller), in cold drawn seamless or better.
MIG or TIG is fine, how well it's welded is more important than the process.
Ripp does it matter if you use tube or pipe for this? IE, is that a MINIMUM pipe ID of 38mm, or is that OD?
That's tube dimensions, so O/D, main issue with pipe is getting something with a high enough minimum yield strength (>350n/mm^2), blue band steam pipe, etc, isn't strong enough unless you're running in series with specific cage exceptions allowing it.
Excellent, thanks ripp.
Pfff scaffold pole be reet. Lol
/Toseland
Why didn't I think of that!
  Mig welding cast bashbarnard 11 6,768 24-03-2017, 09:23 PM
Last Post: bashbarnard
  Anyone with TIG welding knowledge? Jonny81191 10 8,753 21-09-2015, 07:01 PM
Last Post: Jonny81191
  Welding machine Ben 6 7,417 05-06-2013, 05:48 PM
Last Post: Ben
