Gearbox Breather
Hi - am just doing a gearbox oil change - it is SLOWLY filling through the breather - my question is that the black plastic breather I removed from the engine is just a completely open 8mm hole - I was assuming it would have a cap with a smaller breather hole so has my breather got a little cap missing from it ?
cheers max
Yeah, there should be a little white/cream cap over that.
Thanks Tom - will get one !
It is filling slowly because I only have a piece of plastic tube approx. 5mm internal dia
But I am multi tasking and filling myself with coffee at the same time : )
The breather unscrews - 17mm spanner if I remember correctly - from the top of the gearbox giving a much bigger hole to fit through.
Thanks I have the breather off which is when I noticed it did not have a cap on it - it is my size of tube that is limiting the filling speed : )
Ah, fair enough. A funnel with an extension works wonders for this:
[Image: BoxOil4.jpg]
The cap over the breather looks like this:
[Image: 5741_under_bonnet_2.jpg]
Same on any BE3 gearbox as far as I know.
I am using exactly that technique but think mini funnel and 5mm int dia tube - its slow LOL but I am doing other stuff whilst the level in the funnel creeps down : )
It shouldn't be that slow lol... I use a mini funnel as well but takes like 10 mins! lol
I bet yours is bigger than mine Tom Rofl
[Image: DSC01477_zpssnrxqwk3.jpg]
Oh, I forgot how much was in the way on the xud lol, I do hdis and petrols so no tmic!! Same size funnel though oddly, but I put mine straight on so maybe it's the pipe slowing it down.
Yeh definitely the pipe is the limiting factor - I live out in the sticks so it would have taken longer to go get larger dia pipe than how I did it - all done now and cleaned away.
Does anybody have a part number for the Breather assembly please ??  - its way easier for me to order online if I can.
Thanks for the help guys - much appreciated
The black part of the breather (ie what you've already got) is 226830 and is £4.19 inc VAT
The white cap part of the breather (ie what you're missing) is 221816 and is 61p inc VAT
Hope that helps Smile
Blimey less than 13 minutes - what kept you ? Rofl
Thanks very much - very kind !
Where are you in wilts ?
Until xmas I  worked near Amesbury for 13 years - before returning to the frozen north - although its fairly warm today - the sun came out within minutes of me finishing on the car LOL
I know, just can't get the service these days can you? Tongue
I'm in Swindon, so 45 minutes or so North of Amesbury.
Ahhh Swindon - been past it many times Smile
Not sure I have actually been in it but have vague memories of going through the magic roundabout a few times - some years ago !
If you've jammed it in hard...it will be slow as there is no way of the air to escape as you fill...after all you are filling it through the breather! Take level plug out and it will fill up much faster!!
The tube was so small I could move it around in the breather hole (not the threaded part),the restriction was definitely the tube - it was 5mm int dia with a secondary restriction where I had sleeved it into the funnel (not over the funnel  - into the funnel ) - it was a steady flow with no bubbles or farts .
When I did mine a few weeks ago I just cut a milkshake carton up and put the spout in the hole, seemed to work ok and didn't spill.
However this was after changing the engine so the battery and tray weren't in. Not sure on space restrictions once assembled.
can i ask, where do you get mail order pug oe parts from please, local ( and national dealers it seems ) are crap!!
I always start by just googling the part number - sometimes it pays off and will give a link to ebay or to an online part supplier.
I got a breather from ebay ok by doing that - it was relatively expensive (£6 - but still easier for me because of where I live LOL)
(26-03-2016, 04:59 PM)pug306driver Wrote: can i ask, where do you get mail order pug oe parts from please, local ( and national dealers it seems ) are crap!!
Speak to Ed or Steve in Warners Tewkesbury parts. They ship nationally and know their stuff.
P1 XSi track car
2.4 LWB T4
If my local Peugeot dealer doesn't have it/take too long to get it I just put the part number into ebay.
Most recently I needed the pipe that goes from the rocker to the oil filler neck. Peugeot said a week I think. Found it on ebay and it was less than 24 hours from ordering to in my hands.
  oil out of breather under hard cornering zx_volcane 9 7,097 19-07-2017, 11:45 AM
Last Post: zx_volcane
  Oil breather hose Check30 23 14,107 18-03-2014, 01:33 PM
Last Post: padge
  Breather hose billythekid 5 3,625 18-03-2014, 12:18 PM
Last Post: padge
