2.1 pump in 1.9
Will a bosch fuel pump from a 2.1 with lines and injectors fit a 1
9 td?
Yes.
But it will be like swapping a 50pence piece for another 50pence piece.
Same pump/injectors!
its just i have a lucas and wanted a bosch
is it a streight swap?
Yes apart from injector lines wont fit and you'll need to move studs on Lucas pump bracket
the lines with the 2.1 bosch wont fit? getting bosch pump lines and injectors cheap
Nope they wont. Will need bending.
so move it to the other holes which lucas isnt on bend the pipes will injectors fit or just use lucas ones?
Move studs, note firing order of Bosch before removal, different to Lucas, fit to 1.9 with Bosch injectors. Bend a combo of Lucas and Bosch lines to fit as none will be correct. They have different lengths as they're off a 2.1
Does it need bosch injectors or can I use lucas as guys got one injector stuck in?
If you want the bed out the pump use Bosch, however it will run in Lucas just not as effectively
ok cheers one injectors stuck in haha
will injectors from a 1.9 bosch work with the 2.1?
Yeah they're the same.
hopefully have a bosch pump tho been after one for afew days haha hard to get
This just keeps repeating itself!
