What's this pipe?!
So my car has has a minor leakage which started few days ago. Got under today and this pipe was hanging loose just in front of the sump.
What is it?
Picture is taken from just under the front bumper, looking directly under the car.
Thanks
diesel filter drain pipe
^^^ what he said!
GTI6 Info
(04-02-2016, 03:01 PM)madmadmax Wrote: diesel filter drain pipe
So its just water getting drained out?
Er no, fuel
On the side of the filter housing there will be a thumb wheel. This is where you drain the water/diesel. Tighten the thumb wheel to stop it leaking. If it doesn't stop leaking you need to replace an o ring there.
EDIT: Nvm..
(04-02-2016, 03:51 PM)DeeTurbo Wrote: On the side of the filter housing there will be a thumb wheel. This is where you drain the water/diesel. Tighten the thumb wheel to stop it leaking. If it doesn't stop leaking you need to replace an o ring there.
Cheers bud Smile
