Threads: 448
51
about to give the Rallye a service, and I want to give the Rallye a flush through before putting in some decent oil,
So first of what cheap oil should I put in to run around for 100 miles,
And then what decent oil should I drain and replace it with?
Threads: 15
Car Model/Spec: XSi
21-01-2016, 07:32 AM
(This post was last modified: 21-01-2016, 07:33 AM by adam b.)
I'd use any cheap 10w40 semi synthetic but I wouldn't do 100 miles on it. Bring it up to temp for a few minutes then let it cool a bit.
I'm currently using millers nanodrive 10w60 nt competition stuff. Made the engine a lot quieter and smoother. Used total quartz 9000 5w40 for years as it's cheap from Peugeot.
Use Peugeot filters too.
P1 XSi track car
2.4 LWB T4
Threads: 102
18
Rather than flushing I'd just change the oil with total quartz 9000 which is recommended and is cheap enough, and then change it regularly. After lots of regular oil changes it will be coming out cleaner each time.
Threads: 448
51
Is the Quartz stuff what you get from Peugeot?
