BMW E36 325 TDS M51 Head Stud Size (Same as E36 325i? 328i? E28 M21?)
Can't seem to get an answer elsewhere so maybe someone on here can help...
As per the title, what engines have the same size head studs as the M51 E36 325 TDS engine?
Any help appreciated, perhaps someone has like the service box equivalent, I'm trying to source some ARP's.
Same engine as in the Range Rover P38's.
Look like these: http://www.turnerengineering.co.uk/acata...-1046.html
[Image: LDY000040.jpg]
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Measure headbolt then email arps surely be the easiest bet?
(20-01-2016, 03:03 PM)bashbarnard Wrote: Measure headbolt then email arps surely be the easiest bet?
Would rather not remove them until I have a replacement.
If all else fails then that's a last resort.
I've emailed them already and they said they don't stock them but might be the same as other engines (hence the question).
S14 Zenki Build
Ebay/ecp/autodata?
There will be two sizes. One from base of nut/washer to tip and one full length. You'll need the full/total length as you use studs with ARPs
look up realoem.
^^ Said this to you ages ago dude, realOEM!
