Lowering 60mm all round
So I'm gonna be lowering my car 60mm all round. I have nice wheels picked out and I'll be getting good quality tyres on there too.
I want to get a nice stance and good performance out of this and I've thought of going air ride but for now it's too expensive for me and I'd want it all round which is a problem at the rear.
I've opted for these springs in the front http://www.dcperformance.co.uk/cheap/771...69907.html
Has anybody had any experience with these springs ?
And the plan with the rear is to refurb the axle and adjust the torsion bars to lower by 60mm.
I'm wondering which torsion bars would be a good upgrade from my standard 1.4 phase 1 ones ?
And which shocks would be good for my set up ? I'd rather go for adjustable shocks but I'm not sure which ones are decent quality.
if you want good handling these
http://www.dcperformance.co.uk/cheap/106...0-120.html
coupled with these
http://www.kamracing.co.uk/car-tuning/pe...r-kit.html
coupled with a gti axle built by
http://306oc.co.uk/forum/archive/index.p...28869.html
that should see you a very good handling setup. any lower and the handling get worse for road/track use imo. i have mine at 60 wish id never done it
air ride? I believe there are some kits & specialists around.
just a thought, would a beam minus it's torsion bars be a place to start for fitting a kit?
for instance - - http://www.airride.co.uk/air-suspension-...etsvalves/
Hate Housework!
(17-01-2016, 08:07 PM)bashbarnard Wrote: if you want good handling these
coupled with these
Thank you for the links dude Smile I'm trying to keep costs low on it so I wouldn't be able to purchase shocks like that, Would you recommend anything that's cheaper ? Also I'm gonna do the subframe mysef cause I want to learn more about them myself and my budget is limited for now haha. I'm looking at fitting 17" x 9" rota gtrd's which I'll need hubcentric pcd adapters for.
Am I mad thinking these will fit in my arches ? I've taken measurements but I'm not entirely sure
(17-01-2016, 08:52 PM)Magenta Sunset Wrote: air ride? I believe there are some kits & specialists around.
Just had a look at that there I'll definitely have to start drawing up plans for a custom kit like that.
Would the torsion bars not foul on something ? Or could I put them in place of the shocks ? And have another set up for shocks elsewhere that are more suited for air struts ? Or those two in one struts ?
http://www.dcperformance.co.uk/cheap/689...60901.html
Just been looking at these. Could be worth putting the money aside for. Any thoughts ?
afaik, the torsion bars run across the width of the car, either side of the beam,.
(to understand function, take a 30cm plastic ruler, hold both ends & try twisting it).
the shocks could foul the airbags depending on where you locate the bags.
it may be possible to lose the shox, I vaguely recall that air suspension may be self damping. (bike shox were- - )
Hate Housework!
(18-01-2016, 01:53 PM)Magenta Sunset Wrote: afaik, the torsion bars run across the width of the car, either side of the beam,.
Oh I know that trust me haha I've been in and around all of it and been learning all about them, Quite interesting really and one of my favourite parts of the car so it'll be a shame to see them go but I can't see them coping with what my needs will eventually be so.
Yeah that's what I was thinking and the bags could also foul my stupidly wide wheels hahaha, that's easier to fix and I think there self damping too which makes me think I can modify the mounts where the original shocks sit and install the bags there
welllll, if you're fabricating things, then mounts & brackets could be fitted where you have clearance (within reason, of course)
you'd only need to retain the ARB
Hate Housework!
Yeah I'm having ideas now haha.
Gonna go jack it up, take pictures and get size & weight specs for the rear so that I have everything there when I go to do it Smile
ThumbsUp
Hate Housework!
Thanks given by: Adam CD P1
(17-01-2016, 07:54 PM)Adam CD P1 Wrote: So I'm gonna be lowering my car 60mm all round. I have nice wheels picked out and I'll be getting good quality tyres on there too.
GTi tb's and arb will be a huge upgrade. 20mm tb's from 18mm and 23/24mm arb from 16-20mm arb. Although if your on a tight budget a whole gti axle will be easier providing you know the history of it.
Personally i wouldnt lower it that far puts much more pressure on the moving parts, i for one wont warrant my axles if set at -60mm or over.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
You're not going to fit 17" wheels, 9" wide in there without serious bodywork adjustment... And thats without 60mm drop.
Do it safe or go home. What Bash linked you to is a cheap enough option tbh
That's a good idea actually and I'd get disc brakes etc with the gti axle too wouldn't I ? Everything that goes into this isn't going in unless it's perfect so if I get a used gti axle i'll be making sure everything's perfect on it first before it goes in.
How low would you say I can go ? Piggy recommended 30mm would be the max for good performance etc but I'm looking for nice wheel fitment too and I know it's often difficult to get a balance of the two but I'd like to be as close as possible to that balance
  lowering hdi 50/60mm ct-hdi 17 7,566 04-02-2016, 10:01 PM
Last Post: ct-hdi
  car feels skittish round corners? it never did befor an ideas guys ? jjenn20 9 4,331 04-04-2015, 01:04 PM
Last Post: jjenn20
