stiff lower gears selection
I've read the threads ref changing linkages/bushes, but I don't think it's the answer I seek.
Engine is DW10 (90hp) with a 'right & back' reverse.
only a small niggle, but when the engine is cold, 1st & 2nd (mostly) are diff to select & release.
Seems better when engine has warmed up.
Would a 'box oil change do the trick on improving that?
thanks.
Hate Housework!
Using non genuine 'box oil usually causes this. Replace it with genuine stuff and that should help!
thanks Tom,
not sure what's in there. not been done since I've owned it.
(job for spring then)
Hate Housework!
Mine does this. As tom says gearbox oil. The pug stuff has something specific in it. No idea what. Mines really bad but cba to work on it. Lol
Thanks given by: Magenta Sunset
  Really stiff gearstick djyo 30 16,769 05-04-2018, 05:56 AM
Last Post: mangler
  BE/6 Gearbox Selection Issues Maccer 2 3,101 22-08-2017, 02:50 PM
Last Post: Maccer
  Rear beam stiff on one side WILL1000 14 6,547 23-08-2015, 10:05 PM
Last Post: Jonny81191
