19-12-2015, 09:00 PM
It goes, it stops (as reqd).
Hate Housework!
Hate Housework!
anyone ever come across these?
![]() Hate Housework!
19-12-2015, 09:01 PM
Yeah my s16 had them on when I got it
19-12-2015, 09:03 PM
yeah they were on most 306s as standard afaik, also on most new pugs and citroens aswell. once the balljoint has been out a few times though they get worse for wear and most people never out them back.
19-12-2015, 09:04 PM
They all have them!
19-12-2015, 09:05 PM
(This post was last modified: 19-12-2015, 09:10 PM by Magenta Sunset.)
ah! cheers guys
![]() secondary question, why & are they needed?
19-12-2015, 09:14 PM
they are a heat shield to stop the heat from the disc melting the grease in the boot of the ball joint
19-12-2015, 09:27 PM
double ah!
worth checking & refitting if missing then?
19-12-2015, 09:30 PM
ideally worth fitting yes
Do i use them? No Have i noticed any side affects? No
19-12-2015, 10:11 PM
now that's a valid point, and one thing less to bother about.
20-12-2015, 12:21 AM
20-12-2015, 01:20 AM
(20-12-2015, 12:21 AM)Mattcheese31 Wrote:(19-12-2015, 09:04 PM)Toms306 Wrote: They all have them! Same as that, though I've only had 3. ![]() ![]()
20-12-2015, 09:25 AM
They should theoretically extend the life of your balljoints significantly, don't know how well they work in rl though. Most cars seem to have similar, so i presume they must work.
(20-12-2015, 01:20 AM)WiNgNuTz Wrote:(20-12-2015, 12:21 AM)Mattcheese31 Wrote:(19-12-2015, 09:04 PM)Toms306 Wrote: They all have them! You guys must manage to buy dogs where I only buy decent ones... ![]() I've bent so many of them trying to pop lower BJs out with chisels and crowbars over the years lol. ![]()
20-12-2015, 09:39 AM
Unless you're getting your discs properly hot, I doubt you'd notice the difference. A lot of manufacturers have holes in the brake shield where the ball joint sits, and it's a lot closer than the 306 ones. If you can be bothered, run them. I really wouldn't get hung up on it though.
20-12-2015, 10:04 AM
most get lost/damaged if a BJ/wishbone/hub is replace and as above, most people dont worry about breaking them and leaving the replacement BJ without.
if you've still got them, its either never had its lower arms off or its seen some sympathetic mechanics in its time some of my AX/saxo/106's have also had them.... though, some have not and ive never noticed a problem from not having them fitting.
20-12-2015, 11:01 AM
thanks everyone. won't bother replacing them
20-12-2015, 12:21 PM
Mine's still got the original balljoints/protectors on after 16.5 yrs so they must have some benefit & these are cheaper to buy from the dealers than the one you linked.
20-12-2015, 02:29 PM
just replaced both of mine with new
![]() were pretty torn up after all the miles! |
