Rear lights
Rear lights
The rear o/s light on my phase1 doesn't work. Brake, indicator work only the side light working. Swapped bulb, swapped light unit.????? Would a blown fuse control just one bulb?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Take light apart, clean all bulb contacts and try again
As above... Also add a earth to the board if still no better...
It could be a blown fuse. Do your sidelights on the front work? They are on the same fuse as the O/S rear light on a Ph.1.
I have had the exact same problem and it was the fuse for the sidelights that had blown. Check that plus any other fuses you can find.
Here's a list of fuses, look at F4:
http://www.peugeotlogic.com/fuses/fuses3...elist7.htm
62k Diablo Phase 1 Gti-6:
Project Thread
It's earthed already. Front lights work. I'll give the contacts a good clean tomorrow. Cheers.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Sidelights definitely work? On a Ph.1 there's a dim dip relay that makes the headlamps come on faintly when the sidelights are lit so that if they do die there is some illumination.
Project Thread
  Instrument lights, dash lights not working boggs 3 4,535 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  Rear lights. Paulb306 6 3,326 06-11-2015, 10:15 PM
Last Post: Paulb306
  Rear brake lights staying on Welshy_Pete 8 6,989 19-04-2015, 06:24 PM
Last Post: Welshy_Pete
