What oil did you put in? These boxes tend to be a bit fussy about gearbox oil, if you used something else it's probably worth draining and refilling with the recommended fluid.
Threads: 145
comma say their oil is ok for 306 g/boxes, opinions please, so should I just get the pug stuff?
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
Direct from Peugeot is cheap enough to not worry about buying elsewhere
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
It's Total 75W-80 you want for PSA boxes.
Not sure what Pug want, but I tend to order a few litres at a time ( I have 3 Peugeots) from
here.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 11
I did put Total 75w-80 in May, i was delighted with the gearbox, very soft and smooth...now since last month i feel a bit "crunchy" when a stick a gear up, when press the pedal i can hear a little squeak, i think is the release bearing...the car have 200k, i don't know when was been change the clutch
Honestly i would drain it and bang in some total BV 75w-80. I don't know why but these boxes seem to run shite on anything but that. Ive never seen a explanation as to why but i think just about every regular member on here has experienced it them selves so too much of a coincidence!
Have you removed the spring on the clutch pedal? Does sound like clutch problems.
