Threads: 163
53
Car Model/Spec: 406 HDI
Pulling my hair out over this. So, when I was in Cornwall the blower just didn't come on when I turned the key one morning. I googled it and apparently its usually the blower speed controller, so I replaced this, still dead, sent that back. Then I read that it can also be the fan itself, replaced that, still dead, sent it back.
So decided to get technical. Apparently there's a switch on the back of the ignition barrel that only supplies power to the blower motor fuse, checked it with a multimeter and there's 12v at the fuse with the ignition on, so no problem there. Checked the motor plug, and that's where it gets weird. There's 2 wires, red and black. Black has no voltage, think it might be earth, but red has 12v regardless of whether the blower is even switched on? How is that possible and if so why isn't the fan running?
I hate electrics. Any ideas guys?
Threads: 25
3
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
Try putting 12v on the fan to make sure it works first. The black could be a switch wire and the motor is grounded from the body?
Threads: 163
53
Thanks mate. Can I literally just connect a wire from the battery positive to the pin on the motor?
Threads: 5
1
Car Model/Spec: 306 GTI-6
Given 7 thank(s) in 7 post(s)
Have you already checked the ignition switch?
My 406 use to be like this by the blower can be operate if we supply 12V direct to it.
After find every related part and connector, I swap the new ignition barrel and they can properly work.
The cause of problem of my 406 came from poor contact of ignition barrel..
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
Threads: 163
53
I did yeah, the switch at the back feeds a 40A fuse in the fuse box, I checked the fuse terminal and it has 12v with the ignition on. I heard that was a common issue.
Threads: 25
3
Just make sure you have you've polarity correct. But yeah I'd stick 12v on it and make sure the fan works first.
Threads: 163
53
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
(08-07-2015, 05:59 PM)THE_Liam Wrote: Whats polarity?
Determines which way the fan turns I think. So if it sucks (easy  ) you could switch the positive and neutral around for it to blow.
I think.
Threads: 163
53
Think I'm gonna throw in the towel and go to an auto electrician to be honest
Threads: 55
17
Car Model/Spec: 406 V6
The red does get 12v all the time - the current to the motor is controlled by the resistor/solonoid pack - I will say if you bought an ebay resistor then borrow a working one to check it, because I had that issue - 2 dead ones new from ebay....
Threads: 465
114
Car Model/Spec: Vauxhall
as rip says try a new/different fan control module they are an electronic module not a resistor pack
they switch the ground on the fan motor, and yes the fan should have 12v all the time the ign is on
drawing for you if you can read it
8050 is the fan blower
8045 is the electronic module
liam.pdf (Size: 294.27 KB / Downloads: 131)
Threads: 163
53
Cheers lads I'll have a punt on another.
Threads: 58
Car Model/Spec: v70r
Given 1 thank(s) in 1 post(s)
Have you tried tapping the relay or listening for a click whilst working the switch?
Threads: 117
119
These are earthed back into the loom iirc, checked you've got a clean earth? Shit aftermarket controller is pretty likely though, see it a lot at work.
Threads: 163
53
Tempted to just tap into an ignition live and hard wire it to be honest...
Threads: 55
17
Is it the early or the late controller?
Can borrow mine if you're nearby, it's on axle stands at the 'mo anyway
Threads: 163
53
(17-07-2015, 08:57 PM)Rippthrough Wrote: Is it the early or the late controller?
Can borrow mine if you're nearby, it's on axle stands at the 'mo anyway Would have thought its the late one, mines a phase 2. Which is yours mate? Cheers for the offer pal.
Threads: 55
17
Ah, mine is the early one, '98.
Threads: 163
53
Damn, definitely different
