26-06-2015, 06:07 PM
106 Track Toy
26-06-2015, 06:35 PM
I have standard brembo discs on my gti brakes up front, absolutely brilliant.
And for the last few months i have been running mintex1144s... I then swapped to the Ds2500 ferrodo pads... big difference!! I would svave for brembo discs, Ds2500 pads, braided lines (if not already) and some nice race dot4 or decent 5.1 fluid. But to be honest, all that is pointless with rubbish tyres! nice wheel choice by the way, love them on the 106! Wishes for more power...
26-06-2015, 06:37 PM
(26-06-2015, 06:35 PM)Piggy Wrote: I have standard brembo discs on my gti brakes up front, absolutely brilliant. Yeah I think tyres are my next big purchase, and thanks ![]()
27-06-2015, 07:27 AM
Good tyres are mandatory! R888's or Yoko AO48's in soft compund for a lightweight 106, the difference in the way the car performs is simply night and day.
Next big purchase needs to be an S1 rallye close ratio gearbox! try to find one thats already had a GTi 5th gear swap but keeping the S1 final drive ![]() ![]()
27-06-2015, 12:41 PM
(27-06-2015, 07:27 AM)Matt-Rallye Wrote: Good tyres are mandatory! R888's or Yoko AO48's in soft compund for a lightweight 106, the difference in the way the car performs is simply night and day. I like the sound of that gearbox! Have to keep an eye out for a S1 box
27-06-2015, 04:35 PM
Finally got rid of all the tar stuff in the car, horrible job to do. Only took me an hour to get this piece off
27-06-2015, 08:12 PM
Td's looks great Nathan
Id the 406 brembo made a bloody racket and won't amazing I could easily out break them with my yellow stuff now. Definitely look into scatchshifts mate,quality bits of kit. ![]() Astor 6 Fast road/track project
27-06-2015, 09:23 PM
(27-06-2015, 08:12 PM)7057sam Wrote: Td's looks great Nathan I was tempted by 406 Brembos but can't find any about and a snatchshift is definitely on the cards! Not to badly priced either
27-06-2015, 09:40 PM
You won't need brembos, 6 calipers at the most
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
27-06-2015, 09:45 PM
(27-06-2015, 09:40 PM)Stef205 Wrote: You won't need brembos, 6 calipers at the most Fair enough ![]() ![]() ![]()
30-06-2015, 12:27 PM
(This post was last modified: 30-06-2015, 12:35 PM by Nathan1305.)
Fitted my aerial blank today, I think it looks a lot neater
![]() As usual with anything French I find more rust -_- not sure if it's under the side skirt or if it's within the body
30-06-2015, 02:36 PM
you could blend that bit into a cage mount
30-06-2015, 02:41 PM
30-06-2015, 02:42 PM
not much you can do about that other than spray something in there
30-06-2015, 02:44 PM
02-07-2015, 06:03 PM
(This post was last modified: 02-07-2015, 06:06 PM by Nathan1305.)
Gave the car a bit of attention today
![]() Can also notice a big difference in the ported and polished throttle body Next on my list is to get the new shocks on the new beam when they arrive and put that on after Pugfest ![]()
03-07-2015, 03:28 PM
(This post was last modified: 03-07-2015, 03:33 PM by Nathan1305.)
Had a catch tank laying around so I thought I'd put it it the GTi
![]() The washer bottle was previously removed due to a plate being welded in where it was so a washer bag was put just I front the radiator. I didn't like it there because it was restricting the air flow to the radiator. So after some research I'm going to fit a 205 washer bottle in the boot of the car as apparently they were located there on the 205 and is pretty much a straight fit. So I've removed that washer bag as I don't actually use the windscreen washers.
03-07-2015, 10:54 PM
got a 205 rear washer bottle here if you want it
03-07-2015, 11:00 PM
03-07-2015, 11:30 PM
i like customers like you, buy a beam then dont fit it untill the warranty is out!
03-07-2015, 11:34 PM
(This post was last modified: 03-07-2015, 11:35 PM by Nathan1305.)
05-07-2015, 12:05 PM
(This post was last modified: 05-07-2015, 12:06 PM by Nathan1305.)
I've relocated the catch tank it's mounted on a bracket coming off the engine block, much happier with it there. Need to invest in some proper silicone hose for it. That crappy blue hose just folds in on itself
09-07-2015, 02:37 PM
(This post was last modified: 09-07-2015, 02:39 PM by Nathan1305.)
The 205 washer bottle came today
09-07-2015, 04:48 PM
WTF is this!! could we not find a shorter bolt?!
09-07-2015, 05:09 PM
10-07-2015, 05:42 AM
You still put it on the car like that.
![]() Haven't been in here for a while, it's all looking very tidy.
10-07-2015, 06:49 AM
10-07-2015, 10:43 AM
In fairness I could of shortened the bolts but it's quicker and easier just to throw a couple of extra nuts on them.
Nathan I have a couple of nice yellowy road legal all weather H4 bulbs that have come out of my 106 if you want them. Can bring to pugfest.
10-07-2015, 10:53 AM
(09-07-2015, 05:09 PM)Nathan1305 Wrote:(09-07-2015, 04:48 PM)Stef205 Wrote: WTF is this!! could we not find a shorter bolt?! bet the catch tank is empty too if it was from DD ![]() I'm no perv expert, but that KnN looks awful small and with no cold air flow to it ![]() Wishes for more power...
10-07-2015, 11:14 AM
