Immobiliser
Hi all.
          Here I go again. I am still struggling with start problem.  Car will start ok in morning, run for a few miles and stop/switch off for5 mins or so.  The motor will not start unless I switch off again and restart which is ok for now.   My question is why it will start on second turn?   I have noticed that if I don't hear the lift pump kick in it will not start, hence second turn of key.   Surely this is a immobiliser problem.      I have fitted a new lift pump, so no probs there.
 If immobiliser how can I by pass it or have it reset/repaired?  Doh
Take a look at the fault codes with something like PP2000 - that'll tell you if the immobiliser is playing silly sods.
I can't remember on a HDi if the lift pump will run with the ECU locked - I know on a GTi-6 it does though.
Might be worth checking/replacing the injection relay if there is no immobiliser faults logged, as that can cause similar issues.
Bad earth can do some silly thinks
Thumbs Down Immobiliser thebluepearl 11 5,889 20-05-2016, 12:05 PM
Last Post: insomaniac45
  Xantia 1.8 16v key/immobiliser Piggy 7 5,396 26-02-2016, 04:02 PM
Last Post: Toms306
  immobiliser problems roemer 5 4,360 21-09-2015, 10:41 PM
Last Post: Pug30614
