Correct grease for axle rebuild?
Do people use specific greases in their axles or just whatever they have lying around?
[Image: 20120704_212316.jpg]
According to my Haynes Citroen ZX manual (the Owners Workshop Manual), there is a special grease called Mobil Temp G9 for the ARB end plates and seal lips on the tube ends. Although, it does say a good Molybdenum Disulphide grease can be used instead. Halfords sell it in tubs.
The Moly grease is also used on the splines, but I have used anti-seize compound in the past. 'Those' beams came to pieces easily (read - a couple of pulls on the slide hammer) when doing my annual check/regrease/replace seals.
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Thanks for that, don't know why I didn't think of looking in the manual! I'll get myself one of those greases soon, then just need a few fixings etc from Peugeot and should be good to go.
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,342 18-04-2019, 10:14 AM
Last Post: Mighty306
  Is this kit correct? :) JTaylor2005 9 5,775 15-12-2015, 02:08 PM
Last Post: powerandtorque
  Rich w roller bearing wishbone grease nipple size Paul_13 1 2,329 31-08-2015, 11:10 AM
Last Post: rryan
