gti6 exhaust
My mid section is taking a beat on speed humps. if I put a straight pipe in and it has standard backbox exhaust would it be a lot louder and what size pipe is best for it thanks
Yes it will be much louder with the midbox gone, but not sure with standard back box.
I currently have straight pipe to scorpion back box and sounds epic!
It has a cone at front so screams and don't want same at back lol
Standard back box is quite big might just give it a bash as mid section is fooked now
slow down over the bumps!
should clear unless its stupid low.
If you remove the midbox and fit the straigth pipe instead, You will hear a louder noise under the center console and when you drive on the highway, You may need to adjust the audio volume lounder Smile
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
[Image: 150521115952.jpg]
It won't be much louder with a standard backbox and a straight-through mid-section. It will sound a bit more 'growly' but the volume won't increase much.
62k Diablo Phase 1 Gti-6:
Project Thread
I've got an aftermarket back box on mines with a stainless steel pipe between it and the cat! It's only really loud when you floor it. Smile
If your midsection is getting caught on speedbumps, surely you'd be better off either fixing it so it's not hanging too low or driving a bit slower? Unless your car is on the floor, in which case stop whinging Tongue
This is the same setup I had on the 1.8. Decat, straight through centre and standard back box. Pops and bangs destroyed two back boxes and bits of metal flew all over the road. Sounded awesome though... 5/5 would recommend.
Not whinging just wondering if any one has done it before and yes is bit stupid low lol
Axle was fooked fitted a hdi one adjusted to same as the 6 one (now stupid low)i read the bars are different size this would make it go lower yes ??
Backbox holds the volume, midbox holds the tone. Mostly at least. This is what I've always found.
Resident cat lover
  Gti6 exhaust manifold connorp 0 1,783 02-07-2015, 06:44 PM
Last Post: connorp
  Gti6 exhaust manifold connorp 1 2,488 01-05-2015, 07:16 PM
Last Post: Niall
  GTI6 Exhaust Size? aaddzz123 3 3,063 10-03-2015, 12:45 PM
Last Post: RetroPug
