Am I missing a pipe?
Is it just me or am I missing a pipe from here? When engine is hot and stood it sometimes releases a little pressure along with coolant.... [attachment=22600]
I suppose you are missing the pipe, but on mine, that pipe is literally only about 4" long at most! So it's not like you're missing much! Wink
Rite that's fine then.... I will get a bit of general pipe just to route it so it doesn't leak everywhere lol. Cheers mate
It's just the overflow, if its chucking it out regularly there may be an issue.
I have only recently noticed the dried coolant around the tank as you can see in the picture. Watching it idle after a long drive it spat little bits and bobs out just few drips really as it got to around 80 degrees on the gauge....temp usually is around 72/75 ish on the gauge.
Weathers getting hotter, it's normal.
Not if you don't regularly overfill your header tank it's not, it's probably just the cap getting a bit old. Should sit around 80, probably got a stuck thermostat there.
Really! I have always been told hdis sit lower 70s normally! When it went to 80 sat on the drive I just put that down to engine warming itself before fans kicked in.
I struggled to find a max marker on the coolant tank too so I just filled it the top of the bit of plastic inside the tank sat in the middle
(11-04-2015, 09:13 AM)td163 Wrote: Really! I have always been told hdis sit lower 70s normally! When it went to 80 sat on the drive I just put that down to engine warming itself before fans kicked in.
It says 'max' under the red arrow in your pic Tongue
Its halfway up where the lip is
I mean cause it's not see through its hard to tell looking inside the tank when it hits the seam lol
Yeah that seems to be a popular misconception...
That plastic marker is the level indicator for the exact reason you've stated, so that should be fine.
Cheers mate! I'll start buy sorting the thermo & a new coolant cap see how we go. Smile
  missing relay pug306driver 10 4,890 25-01-2016, 12:58 PM
Last Post: DeeTurbo
  Bit of a stange one missing and back firing titch 24 11,503 29-08-2014, 04:27 PM
Last Post: titch
