06-03-2015, 10:06 PM
106 Track Toy
06-03-2015, 10:21 PM
As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this.
As you could buy little rubber grommets and fill in the holes. In side the car.
06-03-2015, 10:24 PM
(06-03-2015, 10:21 PM)procta Wrote: As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this. Gonna leave a single ram in there just about holds it up ![]()
06-03-2015, 10:26 PM
(06-03-2015, 10:24 PM)Nathan1305 Wrote:(06-03-2015, 10:21 PM)procta Wrote: As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this. easy that one, get your self down to the local scrappy and get your self a set.
06-03-2015, 10:27 PM
(06-03-2015, 10:26 PM)procta Wrote:(06-03-2015, 10:24 PM)Nathan1305 Wrote:(06-03-2015, 10:21 PM)procta Wrote: As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this. Don't think there's any decent scrap yards in Bristol any more
06-03-2015, 10:29 PM
(06-03-2015, 10:27 PM)Nathan1305 Wrote:(06-03-2015, 10:26 PM)procta Wrote:(06-03-2015, 10:24 PM)Nathan1305 Wrote:(06-03-2015, 10:21 PM)procta Wrote: As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this. ebay will be your best bet, give the breaker a email and ask. they could even do you a discount on a second set too.
06-03-2015, 10:33 PM
(06-03-2015, 10:29 PM)procta Wrote:(06-03-2015, 10:27 PM)Nathan1305 Wrote:(06-03-2015, 10:26 PM)procta Wrote:(06-03-2015, 10:24 PM)Nathan1305 Wrote:(06-03-2015, 10:21 PM)procta Wrote: As for the boot, id leave it as it is. As you may want to be in there to put your wheels in the boot. Some racers I have seen have left theirs a lone, and fitted pins for the regs. But it all depends on how far you are going to go with this. I'll have to mail a few ![]()
06-03-2015, 10:35 PM
what about a set of steelies? just to sit the car on?
06-03-2015, 10:42 PM
06-03-2015, 11:18 PM
aahheemm why is that axle not on yet?
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
06-03-2015, 11:20 PM
07-03-2015, 09:57 PM
For securing the door cards rivets will be the lightest and cheapest but self tapping metal screws like I used on my GTi6 is the easiest if you ever need to get behind it.
07-03-2015, 10:04 PM
(07-03-2015, 09:57 PM)Dum-Dum Wrote: For securing the door cards rivets will be the lightest and cheapest but self tapping metal screws like I used on my GTi6 is the easiest if you ever need to get behind it. Yeah I ordered some rivets on eBay ![]() Brakes are next then suspension and seats.
10-03-2015, 10:14 PM
[attachment=22125]
Got some black pop rivets should look a little different ![]()
03-04-2015, 05:31 PM
[attachment=22478]
Got the door cards done today ![]() ![]()
03-04-2015, 06:54 PM
looking bob on there!
03-04-2015, 07:06 PM
09-04-2015, 02:21 PM
(This post was last modified: 09-04-2015, 02:23 PM by Nathan1305.)
Fitted the enclosure thing today, hope it gives it a little cooler air
![]() [attachment=22585] Stripping the car has made it super high haha, it's defying gravity [attachment=22586]
10-04-2015, 03:13 PM
Door cards looking good
Are you in this at action day in a few weeks? ![]() Astor 6 Fast road/track project
10-04-2015, 03:26 PM
10-04-2015, 07:10 PM
Is that with the new axle on?
10-04-2015, 07:15 PM
14-04-2015, 11:34 AM
So buying lowering springs today but undecided weather to go 50mm or 60mm lower. Now it's stripped it's sitting very high. I measured the gap between the arch and tyre and it's around 90mm so what springs would you put on it?
14-04-2015, 06:44 PM
I suppose it depends how low you want it.
Have you considered coilovers?
15-04-2015, 03:24 PM
Cage is only about 25kg though mate, put 25kg of weight on the back seats and see how much it changes (2 alloys with tyres will be close to 25kg)
Personally I'd be going for the 60mm
15-04-2015, 07:29 PM
15-04-2015, 09:02 PM
I bought half-decent coilies needing a refurb for £180, refurbed them for about £80. So that's £260, a half-decent shock and spring set will cost you more than that new...
15-04-2015, 09:09 PM
(This post was last modified: 15-04-2015, 09:09 PM by Nathan1305.)
(15-04-2015, 09:02 PM)Poodle Wrote: I bought half-decent coilies needing a refurb for £180, refurbed them for about £80. So that's £260, a half-decent shock and spring set will cost you more than that new... Gone for just springs for now then I can develope it more over time. Hoping to get it all fitted for FCS. Need 266mm brakes and rear disk setup |
