Coolant system component identification
[Image: 240d9ec8945d54bbe95edb796d0c0862.jpg]
Anyone got a part number for one of these?
Need one ASAP. To fit a hdi
Cheers
If anyone can look up on service box would be great
I've got a spare I can post out if you cant get one. £5 plus postage. Can get it posted tomorrow first class.
Sweet yeah, is it Definately from a hdi?
No but I do believe they are the same. I will check part numbers in a bit. After I've had my tea for you. Smile
That's great much appreciated
1336 Q3 thats the part number you want. the xud number for the same part is 1336 g4. not sure what the diffrence is though
cant tell the difference by typing the numbers into ebay.
Pm'd you
Think i've got one from an hdi kicking about in the garage, will have a look in a minute.
The hdi one has the inner top pipe blanked off IIRC.
Yeah the one I had was blanked off on the inner hole, i drilled it out as I need both open and unfortunately didn't do a very good job of it, hence the wanted thread!
(02-03-2015, 12:38 PM)Sambarker Wrote: Yeah the one I had was blanked off on the inner hole, i drilled it out as I need both open and unfortunately didn't do a very good job of it, hence the wanted thread!
Right I'm sorted, had one of an XUD in the shed and fits
Thanks everyone for help
  best way to clean the coolant system after oil contamination tuttyboy84 7 3,872 25-05-2014, 08:06 AM
Last Post: Poodle
