slight engine issues
iv noticed a couple issues recently and not sure what they are so hopefully someone can help
problem 1 is next to each injector there is a little puddle of oil or fuel cant figure out which
problem 2 is when driving it sometimes smells fumy inside
any help would be great
leakoff o-rings leaking, or main injector seals.
are they cheap enough and easy to replace?
Every HDi I've had has had those little pools of diesel....they take ages to come back after you blast them out with a jetwash so I never bothered rectifying.
As for the smell - change your deodorant, stop eating curry, leave the missus at home... Tongue But seriously, what kind of smell?
lol tom
the smell is like the smell of an exhaust when you start a derv from cold
Probably exhaust getting into the cabin somehow then. Likely to be the fire ring leaking slightly on the cat pipe.
...or those pools of diesel heating up maybe lol.
Tighten up the fuel pipe unions and clear up all the diesel completely using degreaser and a jetwash. Once dry, Let it idle and see where the leak is coming from. If nothing, then take it for a quick drive and check again.
Mine had pools of diesel everywhere, but once i tightened everything up and cleaned it, there's an odd drop leaking from 1 injector seal
is it safe to jetwash engine?
(10-02-2015, 09:59 PM)jayspug86 Wrote: is it safe to jetwash engine?
There's mixed opinions but i jetwashed mine a few times on seperate occasions as there was a lot of grime stuck on it.
I just put plastic bag over alternator/ecu/air intake, whether it matters, i don't know
Before and after:
[Image: 2a9541e5ae90ad3081d66b462c9387c2_zps109c86e8.jpg]
[Image: 2da6fdd5a183880f009d2613a83a792c_zps9eedca39.jpg]
Depends if you like to live life on the edge as I do... Wink
Most people will tell you its not.... I've done it several times without issue though lol.
ok il try cleaning first any recommended degreaser?
(10-02-2015, 10:17 PM)jayspug86 Wrote: ok il try cleaning first any recommended degreaser?
Astonish engine degreaser, only costs like £4 and can easily do 3 seperate cleans. Result above ^  Wink
where can you buy it?
(10-02-2015, 10:27 PM)jayspug86 Wrote: where can you buy it?
http://bit.ly/1AULb6o Tongue
Tbh I just use the cheapest engine degreaser around, £1 a bottle, seems to do the same job!
For localised bad areas I use the foamy lemon degreaser from Halfords lol.
  Engine light always on and had slight run-on CaptainHair 0 2,976 02-07-2020, 08:54 PM
Last Post: CaptainHair
  Slight exhaust issue aircool 7 5,320 30-04-2012, 01:25 PM
Last Post: Poodle
