I've just bought some must jets, how the hell do you remove the old washers? Ph3 btw
Stupid question
10-02-2015, 05:30 PM
Push them up from underneath. Watch your fingers though, sharp edges around them!
10-02-2015, 05:31 PM
10-02-2015, 05:33 PM
No worries... About 50% chance you'll be back in a minute saying they aim too low if they're ebay ones...
10-02-2015, 05:34 PM
10-02-2015, 05:39 PM
I had an argument with an ebay supplier where I got mine lol, they stated the part number in the title and were adamant they only sell one type....umm, you're selling the wrong type then, or change the title!
I did find a genuine set in fiat dealer packaging for just 6.50 the pair though, on ebay as well, csn post the link if anyone stryggling to find the right ones.
Push side to side from underneath, can be a bit stiff sometimes
10-02-2015, 05:51 PM
I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway
10-02-2015, 05:58 PM
10-02-2015, 06:00 PM
Out of curiosity, how low do they spray? How far up the windscreen does the top of the jet reach?
10-02-2015, 06:03 PM
(10-02-2015, 06:00 PM)Iceman299 Wrote: Out of curiosity, how low do they spray? How far up the windscreen does the top of the jet reach? Somewhere between half and 1/3 up the windscreen id say
10-02-2015, 06:21 PM
10-02-2015, 06:22 PM
(10-02-2015, 06:03 PM)Niall Wrote:(10-02-2015, 06:00 PM)Iceman299 Wrote: Out of curiosity, how low do they spray? How far up the windscreen does the top of the jet reach? And the proper ones about 3/4 of the way up? I've had 2 306's with mist jets and they always have 1 jet spraying 10cm or so lower than the other, well weird
10-02-2015, 06:45 PM
The times ive had the wrong 1s they seem to just spray at the wipers. When i got the right 1s they come in a Fiat bag like Tom said
10-02-2015, 07:15 PM
(10-02-2015, 05:51 PM)Iceman299 Wrote: I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway Luckily I had more patience, just lol as I've just refitted the old ones unblocked and aligned them
10-02-2015, 09:49 PM
(10-02-2015, 05:51 PM)Iceman299 Wrote: I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway Top tip for you, use gloves and keep the washer tubing on, pinch the pipe tightly underneath the end of the jet and push straight up. Hasn't failed for me yet and my jets are still useable if need be. ![]() (10-02-2015, 05:58 PM)Bassman85 Wrote:(10-02-2015, 05:33 PM)Toms306 Wrote: No worries... About 50% chance you'll be back in a minute saying they aim too low if they're ebay ones... Lol, from neat car parts? Spray just the wipers...? ![]() (10-02-2015, 06:45 PM)Frosty Wrote: The times ive had the wrong 1s they seem to just spray at the wipers. When i got the right 1s they come in a Fiat bag like Tom said This is the correct listing for anyone else wanting the Fiat ones - http://www.ebay.co.uk/itm/221656280057?_...EBIDX%3AIT (10-02-2015, 09:49 PM)Toms306 Wrote:(10-02-2015, 05:51 PM)Iceman299 Wrote: I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway Anther top tip is, if you are going to just take the tubes off and push them out from underneath, make sure you at least have a cloth or something over them to stop them falling down inside the scuttle.......especially if you got the new one and find out its wrong and push it out.....down into the scuttle ![]() Just ordered a set from the link you gave. Fingers crossed lol
15-02-2015, 10:11 PM
Well look what arrived. I fitted them but they still seem like scuttle washer jets haha but it seems with these your able to angle the fronts up a bit but time will tell if they stay like that :/ I'll give an update in a few days.[attachment=21679]
15-02-2015, 10:14 PM
You cant angle them at all.... Should hit the middle of the screen!
15-02-2015, 10:17 PM
15-02-2015, 10:43 PM
I don't mean the actual jet is adjustable, sorry should have been clearer. I've put them on so the fronts are not quite down flush and they are fine then. If I put them flush they spray the bottom of the screen :/
15-02-2015, 10:46 PM
Not having much luck with these are you?
15-02-2015, 10:53 PM
Sounds like you have a broken bonnet then...
16-02-2015, 01:53 PM
Search on ebay for the Xsara mist jets, I fitted mine yesterday and they're excellent!
Link: http://www.ebay.co.uk/itm/221656280057?_...EBIDX%3AIT
16-02-2015, 05:07 PM
They're the ones I already linked...
19-02-2015, 08:56 PM
I've come to the Conclusion that my washer motor isn't performing 100%
19-02-2015, 09:02 PM
Something else broken on your car? That makes a change...
20-02-2015, 10:20 AM
20-02-2015, 10:38 AM
| Maybe a stupid question | kyleo92 | 2 | 2,389 |
22-08-2012, 06:28 AM Last Post: kyleo92 |
