Stupid question
Stupid question
I've just bought some must jets, how the hell do you remove the old washers? Ph3 btw
Push them up from underneath. Watch your fingers though, sharp edges around them!
Thanks given by: Bassman85
(10-02-2015, 05:30 PM)Toms306 Wrote: Push them up from underneath. Watch your fingers though, sharp edges around them!
Cheers buddy
No worries... About 50% chance you'll be back in a minute saying they aim too low if they're ebay ones... lol
(10-02-2015, 05:33 PM)Toms306 Wrote: No worries...  About 50%  chance you'll be back in a minute saying they aim too low if they're ebay ones... lol
I got mine from ebay and they were fine. Must've been lucky considering the amount of people that get the wrong ones!
I had an argument with an ebay supplier where I got mine lol, they stated the part number in the title and were adamant they only sell one type....umm, you're selling the wrong type then, or change the title!
I did find a genuine set in fiat dealer packaging for just 6.50 the pair though, on ebay as well, csn post the link if anyone stryggling to find the right ones.
Push side to side from underneath, can be a bit stiff sometimes Smile
I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway
Your a psychic!! :O lol States part number in listing n all well annoyed Sad
Out of curiosity, how low do they spray? How far up the windscreen does the top of the jet reach?
(10-02-2015, 06:00 PM)Iceman299 Wrote: Out of curiosity, how low do they spray? How far up the windscreen does the top of the jet reach?
Somewhere between half and 1/3 up the windscreen id say
Mine (the wrong ones) sprayed just above the wipers lol
And the proper ones about 3/4 of the way up? I've had 2 306's with mist jets and they always have 1 jet spraying 10cm or so lower than the other, well weird
The times ive had the wrong 1s they seem to just spray at the wipers. When i got the right 1s they come in a Fiat bag like Tom said
(10-02-2015, 05:51 PM)Iceman299 Wrote: I ended up using pliers to twist/turn them from underneath. Wrecked my standard washer jets doing it that way but i have very little patience and they were going in the bin anyway
Luckily I had more patience, just lol as I've just refitted the old ones unblocked and aligned them Sad
Top tip for you, use gloves and keep the washer tubing on, pinch the pipe tightly underneath the end of the jet and push straight up. Hasn't failed for me yet and my jets are still useable if need be. Smile
Lol, from neat car parts? Spray just the wipers...? Itwasntme
(10-02-2015, 06:45 PM)Frosty Wrote: The times ive had the wrong 1s they seem to just spray at the wipers. When i got the right 1s they come in a Fiat bag like Tom said
This is the correct listing for anyone else wanting the Fiat ones - http://www.ebay.co.uk/itm/221656280057?_...EBIDX%3AIT
Anther top tip is, if you are going to just take the tubes off and push them out from underneath, make sure you at least have a cloth or something over them to stop them falling down inside the scuttle.......especially if you got the new one and find out its wrong and push it out.....down into the scuttle Sad
Just ordered a set from the link you gave. Fingers crossed lol
Well look what arrived. I fitted them but they still seem like scuttle washer jets haha but it seems with these your able to angle the fronts up a bit but time will tell if they stay like that :/ I'll give an update in a few days.[attachment=21679]
You cant angle them at all.... Should hit the middle of the screen! Confused
(15-02-2015, 10:14 PM)Toms306 Wrote: You cant angle them at all....  Should hit the middle of the screen! Confused
This. They sit flush to the bonnet, well mine do and definately aren't adjustable
I don't mean the actual jet is adjustable, sorry should have been clearer. I've put them on so the fronts are not quite down flush and they are fine then. If I put them flush they spray the bottom of the screen :/
Not having much luck with these are you?
Sounds like you have a broken bonnet then... Tongue
(15-02-2015, 10:46 PM)Iceman299 Wrote: Not having much luck with these are you?
Lol as with trying to sort it pulling to the right and shocking handling Sad
(15-02-2015, 10:53 PM)Toms306 Wrote: Sounds like you have a broken bonnet then... Tongue
Damn it I thought that was the only bit that wasn't broken Tongue
Search on ebay for the Xsara mist jets, I fitted mine yesterday and they're excellent!
Link: http://www.ebay.co.uk/itm/221656280057?_...EBIDX%3AIT
They're the ones I already linked... Wink
I've come to the Conclusion that my washer motor isn't performing 100%
Something else broken on your car? That makes a change... Itwasntme
(19-02-2015, 09:02 PM)Toms306 Wrote: Something else broken on your car?  That makes a change... Itwasntme
Sarcasm my friend Wink you need it when you own a peugeot Wink
lol
  Maybe a stupid question kyleo92 2 1,722 22-08-2012, 06:28 AM
Last Post: kyleo92
