08-02-2015, 04:22 PM
Any ideas on how to get a stripped bolt or nut out??
Stripped bolt
08-02-2015, 04:26 PM
Which bolt is it? Wheel bolt?
08-02-2015, 04:30 PM
08-02-2015, 04:32 PM
Ah those ones are a right bugger!!
If the threads have stripped and its just spinning you'll have to cut it off, not much access though!
08-02-2015, 04:36 PM
08-02-2015, 04:44 PM
Do you mean a head stud for the manifold or similar?
Have you stripped the thread in the hole on the important bit or just the outside of the stud?
08-02-2015, 04:45 PM
He means the turbo to cat pipe bolt/nut I think?
08-02-2015, 04:47 PM
08-02-2015, 04:48 PM
But you'll still have to cut it in half to get it out...
08-02-2015, 04:56 PM
It's litterally one of two bolts that fit the cat part of the exhasust the ones with the springs!!
08-02-2015, 04:58 PM
Right so if the bolt is stripped then just pull it out?
Or am I missing something?
08-02-2015, 05:00 PM
It just spins, tried to pull it out with pliers but just dosent want to come out no matter how long you wrench it/ pull it!
The nut is spinning on the bolt Chris, stripped/crossed threads, cant tighten or loosen it... It's happened to me a couple of times.
Edit - Just to check, you are counter holding the head aren't you? If not, it will spin lol.
08-02-2015, 05:08 PM
(08-02-2015, 05:00 PM)Toms306 Wrote: The nut is spinning on the bolt Chris, stripped/crossed threads, cant tighten or loosen it... It's happened to me a couple of times. Yes otherwise that would be embarassing!
08-02-2015, 05:18 PM
Is the nut still on it??
Does it budge at all? Have you tried over tightening it to shear it? |
| After a fast road/stripped car | doski | 11 | 6,341 |
14-07-2015, 05:36 AM Last Post: Poodle |
| Taking the stripped out 306 thing a bit far... | powerandtorque | 18 | 11,733 |
05-04-2014, 05:41 AM Last Post: devils_fuel |
stripped | thomson | 15 | 8,011 |
16-07-2013, 07:42 PM Last Post: puglove |
