01-02-2015, 12:31 PM
Long story but I need the return line for my power steering on my XUD
[attachment=21475]
[attachment=21475]
Wanted: PAS Return line
[attachment=21475]
01-02-2015, 12:43 PM
That's not a xud its a gti6. That's not a return line its the pas fluid cooler believe it or not. Some came with them some didn't. You can just remove and bypass. Easy as hell.
01-02-2015, 12:48 PM
(01-02-2015, 12:43 PM)bashbarnard Wrote: That's not a xud its a gti6. That's not a return line its the pas fluid cooler believe it or not. Some came with them some didn't. You can just remove and bypass. Easy as hell. I know but the pipe is the same, its a pic online and how do you bypass it? It was pissing out pas fluid
01-02-2015, 12:57 PM
Follow it up to where it connects to the rubber hoses and join the 2 hoses together
01-02-2015, 12:58 PM
01-02-2015, 12:59 PM
Yeah as above just join the two hoses. Mine had a cooler with a tiny leak on it. Did away with it with the new engine and never had any issues!
01-02-2015, 06:26 PM
01-02-2015, 06:31 PM
Yeah. So what you go is gut the cooler. Cut a good bit out and use that as the join.
01-02-2015, 06:33 PM
A PAS cooler on an XUD!? Whats the point lol? I'm sure I've never seen one on a ph3 until the GTi!
01-02-2015, 06:36 PM
2 of mine had coolers. My current one doesn't. Lus two havnt. No idea why
01-02-2015, 09:03 PM
01-02-2015, 09:05 PM
01-02-2015, 09:14 PM
(This post was last modified: 01-02-2015, 09:14 PM by Nathan1305.)
(01-02-2015, 09:05 PM)Seb_Ryan Wrote:(01-02-2015, 09:03 PM)Nathan1305 Wrote:(01-02-2015, 06:31 PM)bashbarnard Wrote: Yeah. So what you go is gut the cooler. Cut a good bit out and use that as the join. Will do the pas pump is whining like a bitch now haha still very light steering though even though it's lost almost all its fluid
02-02-2015, 09:44 AM
306s never have very light steering.
Don't run it without any fluid though, you'll damage the pump.
02-02-2015, 10:33 AM
02-02-2015, 12:34 PM
Never knew they had coolers, didn't realise it was something that got hot enough to need one.
| Wanted: Bosch fuel return banjo | 306pc | 3 | 2,438 |
01-04-2016, 06:02 AM Last Post: Piggy |
| Hdi injector return pipes | Josh_Quant | 3 | 2,059 |
02-01-2016, 06:57 PM Last Post: Josh_Quant |
| Wanted: K14 or T2 Oil return flange/pipe | 306Puggy | 13 | 5,537 |
26-04-2014, 06:48 PM Last Post: 306Puggy |
